The car will not keep any power..it runs for ten minutes then stop.wont turn back on for at least a day
SOURCE: 2001 Taurus A/C stops for a few minutes then restarts
low side switch on the accumulator is bad see it every other day
SOURCE: 2001 crown vic keeps burning 30A PCM relay fuse
have fuel pump checked i have known a bad fuel pump shorting out causing pcm fuse to blow.
SOURCE: AC Compressor Cuts Out
Do you have gages you can hook up?check preasure when A/C clutch is on preasure low should be about 30 and high should be about 180,if high side is higher you got a blockage some where usealy they will plug at the recever dryer or the expansion valve
SOURCE: Radiator Fan Runs After Car is Turned Off
That is nothing to worry about the fan remains running after the vehicle shuts off in order for the engine to cool down. Once the motor cools down sensors trigger the fan to shut it off.
SOURCE: My 2002 Ford Taurus, just
could be bad water pump,leaking anti freeze,may have blown the head gasket as result overhaeting engine,check oil for milky gray color,or see if coming out exhaust if so blown head gasket,have someone help you check it out
