Gas igniter element
SOURCE: problem with Vulcan Powerhouse 145 cental heating unit.
You should have a high limit switch possible on the bloiwer compartment may be man reset or just bad you do not say how old unit is I would temp jump out high limit to test operation then replace asap
Posted on Jun 11, 2010
SOURCE: I have vulcan powerhouse 100 when
If the fuse is blowing and reblowing after new fuse, measn that you have some short circuit in your system. I suggest check wire connections and device components to secure that problem.
Keep us updated.
Posted on Jun 02, 2011
Nov 25, 2016 | Office Equipment & Supplies
May 17, 2012 | Vulcan Heating & Cooling
Jul 13, 2011 | Vulcan AUW230A Heater
Dec 11, 2010 | Kenmore Dryers
Hi
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the continuity of the heating element in your gas dryer using a multimeter. Replace the element if continuity is not there.
3. Inspect the thermal fuse if it is burnt out, it is attached to the exhaust duct on the back panel of the gas dryer. Replace if necessary.
4. Check the igniter by first disconnecting it, and then place the probes onto the two contacts of the igniter. The meter should read under 100 Ohms of resistance, if it is above 100 then replace the igniter.
5. Check the continuity on the flame sensor. The sensors are usually located close by the igniter so are easily visible.
Hope this helps...
Daniel
Oct 20, 2010 | Kenmore 74602 Gas Dryer
Hi
Hope this helps...
Daniel
Sep 20, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Jun 11, 2010 | Broan-NuTone 9965 Coil / Ribbon Heater
Feb 23, 2010 | Vulcan Convection Oven - VC44EC-208-1
Jul 16, 2009 | Heating & Cooling
67 people viewed this question
