Watch clip of malfunction here: http://www.youtube.com/watch?v=fCcmKaoSqGY http://www.youtube.com/watch?v=GqilWlWihd4
Cable might not be compatible with the TV. try another wire or use regular video cables. see if you can change channel to 3 or 4 for input? I bet the computer might send a signal that makes the tv flutter like that.
SOURCE: Vizio Plasma HDTV not working, flashing static!
I would start looking for a new set, replacement parts for that set are pricey. Trust me, I just recycled a P50HDTV10A that had a busted screen. I couldn't believe what the parts sold for !!! I don't know your preference LCD or PLASMA, but prices have really come down. So if it's in you budget, treat yourself to a new TV !!! Whatever you do, don't just toss the old set in the trash, toss that puppy on Craigslist and If you can get $50-$70 for it, take the money and run !!!
SOURCE: Black flickering sections of the screen
Hi:
This prolem could be one of two problems, first the inverter board may have bad connections on it, its used to light the lamps in the back of the PDP Panel (SCREEN) second the Digital board may becoming faulty, there may be a faulty IC on the digital board or main system control board.
But first I suggest you take off the back and disconnect all plugs you see and reinsert then firmly to make sure they are on tight.
I found the problem and fixed it! The two wide, flat ribbons connected to the T-Con board had become loose. I re-seated then firmly and used some tape to keep them from moving and now the TV works like new.
My code active
