I am getting a paper jam error of two orange blinks. The paper path has been cleared. I reset the printer already. When I plug it in, the carriage inside moved back and forth and then sits in the middle.
SOURCE: False Paper Jam
Hello, My name is Vikram Kumar Thumu, from India-Hyderabad. I have seen your message on the issue related to Paper Jam error messages even though there is no paper jam in printer . I would like to provide my suggestions on the issue. I hope that this should work for you and will resolve the issue. This issue could happen if there is an issue with any small paper jam in the Printer, or due to the communicational issue . To isolate the issue, I recommend you to perform below steps. Steps are: -------------- 1. Power OFF printer and then please Disconnect the Printer from Computer and then disconnect the Power cable of Printer from wall outlet. 2. Check thoroughly in Printer that there is no small piece of paper in the Printer. 3. Let the Printer be disconnected and idle for 5 minutes. Meanwhile please perform further steps on Computer. Note: The below steps are applicable if you are using WINDOWS 2000/XP/VIsta Operating system in your PC Steps are: -------------------- Perform the below steps to restart the print spooler : 1. Click Start>Run 2. Type services.msc 3. Click OK 4. A Window will pop up with so many services listed. 5. Scroll down to locate "print spooler" in the list, right click on it and click "Restart" 6. Restart the Computer. Once if you are done with steps, please connect the Printer and then Power ON Printer and check the issue. This should resolve the issue for you. If you need any further assistance on the issue, you can mail me at [email protected] . I'll be glad to help you. Bye.
SOURCE: Canon MP610 - Paper jam error message
PLEASE REMOVE THE POWER CABLE AND REINSERT IT IT SHOUL BE OK AND IF STILL PERSIST JUST RESTART THE PC IF STILL RESIST PLEASE LET SOME TECHNICIAN TO CHECK FOR THE SENSOR FOR THE PAPER JAM ...
GOOD LUCK
SOURCE: Canon MX310 paper jam
"Gclanton" had it right.
I had the same problem today. I ended up taking a piece of paper and from the back side started lightly forcing the paper in the back slot. I had the top cover open where you replace the ink cartridges. Towards the back you can see the paper start coming into the printer next to some rollers. On mine there was a small black switch about an inch from the right in the middle of the plastic piece above the rollers. Once I started pushing this paper in I could see this switch was stuck in the down position. After several minutes of pushing the paper in and out the switch moved up and out of the paper path. I then pulled out the paper and hit the ok button and it came on line. This may work better with a piece of card stock.
That switch is the issue. I ended up finding an object lodged against the switch. Needed a flashlight, plastic giftcard and a tweezers to get it out. Works great now.
SOURCE: My Canon PIXMA Pro9000 InkJet Photo Printer paper jam error
Had the same problem with mine. Shook it upside down and cleaned it with air cans after reading this solution for other canon printers:
http://www.fixya.com/support/t119769-false_paper_jam_warning_canon_pixma
To my surprise, it worked perfectly... and was great stress relief.
SOURCE: Canon MP145 Error 2
Just press the green (color) button about 5-10 seconds. Hope this help a bit.
