IBM Lexmark 6781-024 Wheelwriter 1000 Typewriter Logo
Question about IBM Lexmark 6781-024 Wheelwriter 1000 Typewriter
How do i change the correction tape
Posted by alex correa on
dick davis
  • 610 Answers
THE CORRECTION TAPE CARTRIDGE JUST CLIPS ONTO THE BOTTOM OF THE RIBBON CARTRIDGE. THERE IS A CATCH/RELEASE LEVER ON THE FRONT OF THE RIBBON CARTRIDGE.
Posted on Sep 07, 2012
2helpful
Changing correction tape in model SL 105 I am attempting to put in a new correction tape in my Model SL 105. It appears to be moving, but I am getting no correction.
If the correction tape is moving and lifting there is a good possibility that the ribbon or correction tape are old and have changed composition or you have a non correctable ribbon.
DickyO
1helpful
How can we change the correction tape? We are unable to get the correction tape off. We can take out the regular ribbon. The wheels for the correction tape won't come off and we can't get below taking...
1. Use the spacebar or backspace to move the carrier to the center of the platen.
2. Open the top cover.
3. remove the cassette ribbon if installed.
4. Pull off both spools, pressing against the correction tape with your thumbs. Bring it back to a position parallel with the platen, lift it up and out.
5. Pass the new tape through the left guide,behind the ribbon guide. The rough (sticky) side of the tape should face the platen.
6. Attach the feeder spool to the pin on the left.
7. Attach the take-up spool to the pin on the right.
8. Turn the take-up spool counter-clockwise until a small amount of white tape is around it.
9. Replace the cassette ribbon and close the top cover.
10. Press (CODE)+(RESET)(Q) to move the carrier to the previous position.
How to change the correction tape?
Changing the Correction Tape
1) Move the print carrier to the center of the platen using the SPACE or BS key.
2) To replace the correction tape, lift out the typing ribbon cassette (see Changing The Ribbon Cassette) and remove the two spools of the lift off tape by pulling them outwards.
3) Place the empty spool of new tape on the left pin so that the tape winds clockwise. Place the tape around the left guide. Pull the tape around the right
guide and place the loaded spool on the right pin so that the tape unwinds counter-clockwise.
Note: Make sure the sticky side of the tape is facing the platen.
4) Manually turn the left-hand spool in the clockwise direction, tightening the tape until resistance is felt.
5) Replace the typing ribbon cassette.
6) Press the CODE + = (SETTING) key.
Changing the Ribbon Cassette
2) Hold the ribbon cassette on both sides and lift up the front portion (where the ribbon is exposed) to remove the cassette.
3) To insert a new cassette, place the back end of the cassette on the cassette
holder on the carrier and gently press down on the front of the cassette unit it clicks into place.
4) Turn the ribbon feed knob counter-clockwise again to take up any slack in the ribbon.
5) Presss the CODE + = (SETTING) key.
Good Luck!
Go to brother.com, click on support you will find a manual there.
DickyO
Changed correction tape and now it only types gibberish. How do I solve this problem?
The correction tape mat be on wrong and catching the Printwheel, remove the correction tape, check the P/W for bent spokes, try it without the correction tape.
DickyO
1helpful
i have the same problem. can't find a manual anywhere. someone please help
Changed correction tape but still won't work
either; 1. you have a non-correctable film ribbon, (it should say correctable film ribbon on the box or the ribbon itself) you can check by taking a piece of scotch tape, hold it next to the letter you want to erase, sticky side towards the paper, and hit the CORR key, CAREFULL YOUR FINGERS AREN'T IN THE WAY. if it corrects, the ribbons ok. 2. make sure the DULL side of the corr. tape is faced toward the paper
CORRECTION TAPE
correction tapes will not work with multistrike ribbons. You have to use a correctable ribbon. If you can find a white out tape, it will work with multistrike. What model typewroter do you have?
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Correction tape not working
The ribbons and lift off tapes both get old and change composition, get a fresh ribbon and L/O tape then try it.
DickyO
Top IBM Office Equipment & Supplies Experts
Gary
Gary
Fix It Fast...
Fix It Fast...
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
