Is this a software issue or a jack problem. When the computer is plugged up via power supply with the battery in or out of laptop, it will not work. The battery doesn't charge when in laptop but will work as long as i have battery juice. When I take battery out with power supply still plugged in it will not work.
SOURCE: Satellite A100-166 PSAA9E does not charge the battery
Your power controll circuit on the main board is bad, you might need to change that or the entire board itself.. If you can get a technician just to repair the power controll circuit you should be fine. most ppl dont do that cause its difficult. Normally your entire main board is replaced. To fix that i will need to see the board but thats difficult since i am sure you dont live anywhere close to trinidad but i am sure someone close to you will be able to repair it, or your can download your service manual for your laptop and attempt to repair it your self.
SOURCE: Toshiba L35 Laptop will not charge, the charge does not register
Had the exact same problem. New AC adapter fixed it.
SOURCE: Laptop only runs on battery even though p/s is plugged
Hi cgarcia557
this does sounds like a problem with the toshiba power management utility.
Sounds like you've already verified the output voltage on the adapter.
The next thing i would check is for any looseness at the DC power jack on the laptop itself.
if this is snug and the center pin is not loose,
the next thing i would do would be to try reinstalling the toshiba power management utility;
Found here
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
Go to;
Download tab
choose your model
Laptop>>satellite>>a75-s206
#7 file from top of list
09-20-2004Power
ToshibaToshiba Power Management Utility for Windows XP/2000(v1.23.2.5; 08-20-2004; 8.3M)
Save this file to on your hard drive and then run it.
If this doesnt solve your problem, the next thing i would be looking at is a BIOS issue.
If you arent familiar with this type of procedure, its best to have someone on hand who has done a few successful BIOS flashes.
This is done at your own risk, but ive done a very good number of them on all makes and many models with never a problem.
On that same page, the very first file listing is the one that you would need.
02-11-2009BIOSACPI Flash BIOS version 1.60 for Satellite A70/A75 (PSA70U)(v1.60; 02-06-2009; 3.53M)
you will also need an external USB floppy drive.
If you want to undertake this, post back in here and i would be happy to help you with the procedure
If this has helped you, please dont forget to take the time to rate, that gives us the satisfaction that a problem was solved
SOURCE: D/C power jack
http://www.laptopka.com/2006/03/18/removing-laptop-motherboard/
Testimonial: "budmrtn, thank you very much. It was very helpful. I was able to disassemble and assemble my laptop in no time."
SOURCE: My laptop won't turn on even though it's plugged into the recharg
1)Reason
a.No voltage.
b.External shot circuit or overcharge, anti-charge
c.Cells expansion and short circuit caused by direct anode contact and continuous high efficiency electric current overcharging.
2)Solutions:
a.Check if the battery is without voltage or electric current.
b.Avoid short circuit.
c.Avoid collision and pressure among batteries.
d.Charge the battery after it automatically powers off , then full charge the battery.
check above hope it help your laptop.good luck to you!
if you nead to buy a new Toshiba Satellite A100-S8111TD laptop battery please visit:http://www.buy-battery.ca/laptop-batteries.php/1+toshiba+satellite--a100-s8111td------(with--intel--celeron--processors)
if not match model please find one here:toshiba laptop battery
