Question about Philips Magnavox DVD/VCR Dual Player
We cant record from the tv to dvd because of an E 45 error
When we try to record from the TV to dvd we get an error E 45 and the screen will say that we cannot recoed to dvd while its in vcr mode even though it is set in dvd mode
Posted by vanessa saunders on
Victor Linwood Tatro
    New Friend:
I have a Magnavox ZV450MW8A, and have had it for some time. Recently it stopped recording on Sony DVD-RW discs. I searched all over for a reason. On this site I found 2 suggestions. 1 was unplug for 20mins. to reset defaults the other was use canned air to blow out the slot. Did both and the problem went away... For 1 disc. When I put the second 1 in I got the same old problem. Sooo not knowing what did the trick I did both, 1 at a time. Neither worked. Finally at wits end and having a new container of about 20 discs that we just bought. I really did not want to just throw them all away. Which is what my lovely wife had taken to doing. I put the disc in again and again and again. The fourth time I ejected and reinserted it. It accepted the notion that I was not gonna just give in. I don't know, maybe the player/recorder is in cahoots with the manufacturer of the discs but it finally gave up and just let me have my way. I guess perseverance did the trick. Don't give up. Sometimes the blind monkey does find food to live another day.
Posted on May 02, 2015
Carl Hader
    New Friend:
Reverse the dvd
Posted on Mar 03, 2013
5 Related Answers
Anonymous
SOURCE: dvd/vcr recorder/magnavox
I'm on my second Magnavox MWR20V6 recorder in less than a year. I've made close to 1,000 DVDs, mostly dubbing from homemade videos of TV shows, but it's not been easy. They have some finicky quirks that aren't mentioned in the manual.
The second Magnavox I got worked far better than the first, and really has been pretty satisfactory. The first one (which finally just died) never had decent tracking, even when I was copying a video tape I'd made on the same machine to DVD!
I got the error e4 54043e02 on both machines. I'd be using the exact same brand and type of DVD that I'd used for hundreds of other times, but I'd get a new spindle of DVDs and few or none of them could be formatted, and were unusable.
I think the problem might be with the DVDs. I have tried all the brands I could find. I first tried Maxell, as recommended in the manual. They worked fine (both -RW and +RW) until one day they just quit working for me. The worst were the ones that had CPRM printed on the DVDs around the inner hub, but I couldn't find any way to tell (before buying them and opening the package) which disks were this type because the label on the package was identical to the Maxell DVDs that worked. I contacted the company and sent them all the DVD numbers and error codes but they didn't tell me anything. It seems to be some kind of company secret.
Then I tried Memorex DVD+RW 4x and they worked very reliably-- until the last pack I got. I'm getting the e4 54043e02 error again!!! I emailed the company but haven't heard back yet, due to the holiday weekend.
So my big complaint is that I can't find ANY DVDs to use for recording. What I've seen so far on the internet gives me the idea that blank DVDs are kinda junky or unreliable in general, also that it's a VERY good idea to keep those old video tapes, which might end up lasting far longer that DVDs anyway. I'd hoped to get rid of the old VHS tapes due to the storage space needed for them, but it looks like I won't be. Unless I can find good DVDs, I'll just go back to VHS recording.
Incidentally, Memorex gives me the impression that they'll refund my purchase price, while Maxell had no interest in making a refund!!
Also I think the DVD-R give fewer problems, but I use +RW for nearly all my recording because I like to edit them. I'd suggest trying a DVD-R if you get desperate.
Posted on Jan 01, 2008
dafid
  • 4 Answers
SOURCE: Error code E 4 54040990
You need to go into the set up menu and select recording options. On the recording options menu, scroll down to dubbing options. On the dubbing options menu select either VCR to DVD or DVD to VCR.
Recording and Dubbing are not the exactly the same thing. You use the record buttons to record TV directly to VCR/DVD you use the dubbing buttons and set up to record DVD to VCR or VCR to DVD.
Hope this helps.
Dafid
Posted on Jul 19, 2008
Anonymous
  • 73 Answers
SOURCE: Magnavox DV220mw9 won't record from Tv, hard to connect
check out this diagram, paying close attention to the audio video cable hookups.
assume the cable tv box represents the converter box
you are going to come out of the converter box audio and video outputs into the new magnavox dvd/vcr combo audio and video inputs.
Then out of the new magnavox dvd/vcr combo outputs to the inputs on the tv if it has such inputs. The TV will have to operate on the video input 1 or 2 if the tv has such a thing, use the remote for the tv to adjust the input signal to line in 1 or 2 depending on what it has.
If the tv has no coaxial input or audio video inputs then you might have to use an adapter, you can get these from radio shack.
You say it will not record from the tv, but in all actuality the dvd vcr combo is getting the signal from the converter box not the tv, do you understand what I mean here?
So the dvd vcr combo gets input from the converter box so you will have to set it to view signal from the line input you have plugged in from the converter box. line 1 or 2 or whatever the input is.
the tv will have to be set on the line input to view the signal from the dvd vcr combo.
That is as easy as I can put it. Study the diagram closely. You will see what I mean.
Posted on Mar 07, 2009
Anonymous
SOURCE: Recording Error, Can not record on this disc, E 4
magnavox dvd recorder/vcr mwr 20v6. forgotten how to get to the finalize screen
Posted on Mar 30, 2010
Anonymous
SOURCE: can't setup Magnavox DVD VCR recorder
i have just purchased a magnavox dvd vcr player/recorder. I can get everything to work except the vcr. I don't know if my connections are wrong or whatever.
Posted on Jun 29, 2010
I'm trying to copy a tv show from my DVR and the recorder keeps saying Recording Error This program is not recordable in +vr mode. What is +vr mode?
Recording mode is set wrong, change it and try again unless there is an anti-copy signal on recording which some money hungry cable companies do to screw with customers.
Sep 01, 2013 | Magnavox ZV427MG9 DVD Recorder VCR
My VCR-DVD magnavox ZV427MG9 A i get recording error, can't record +VR mode E 45
this is a similar problem with the same code http://www.epinions.com/review/Philips_DVDR3545V_37/content_464296251012?sb=1 The person in this says that the plastic "tab" on the back of the tape was broken off to keep from recording over it, but was unable to use it in a combo like you have. he put tape over the hole and it worked...Is this similar to what you are trying to do? let me know
Jun 11, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
I would like simple steps to transfer VHS to DVD on my Toshiba DVR620KY. I want to copy with the unit alone. Would appreciate your help. Thanks.
Hi ,
Please follow the instructions below to record from VHS to DVD. You may not be able to record from some pre-recorded VHS cassettes due to copyight protection embedded into the recording. You should stick some tape over the copy-protection tab on cassettes prior to recording if the tab has been removed. On some cassettes, there may be a slide switch which needs to be moved to the record/rec position. All pre-recorded cassettes will have the copy-protection tab removed.
1. Switch on the TV and DVD/VCR and select the correct input on the TV for the player.
2. Set the player for the recording direction, i.e. VCR to DVD . . .
- Press the SETUP key on the Toshiba remote to open the on-screen menu
- Use the UP/DOWN arrow keys to highlight GENERAL SETTING then press ENTER
- Use the UP/DOWN arrow keys to highlight RECORDING then press ENTER
- Use the UP/DOWN arrow keys to highlight DUBBING MODE then press ENTER
- Use the UP/DOWN arrow keys to highlight VCR > DVD then press ENTER
- Press the SETUP key again to close the on-screen menu
3. Press VCR to select VCR mode.
4. Insert the cassette you wish to record and fast-forward or rewind it to the position where you want to start recording from. Allow at least 5 seconds extra if not starting the recording from the beginning of a cassette.
5. Press PLAY then press PAUSE immediately.
6. Press DVD to select DVD mode
7. Insert a blank DVD
8. Press the REC MODE button to select the recording mode (XP / SP / LP, etc)
9. Press the DUBBING key to start the recording.
You can watch the VCR while it's recording. When you reach the point where you want the recording to end, press the STOP key. You do not need to repeat step 2 every time you record. The player will stay in VCR > DVD recording mode unless you change it.
Hopefully, you will now be able to record from VCR to DVD. If you need further assistance, please let me know.
Regards,
BElectric
Mar 26, 2011 | Toshiba D-VR4 DVD Recorder/VCR
Recording Error, Can not record on this disc, E 4 54040990 Just trying to record from TV on a Memorex DVD+RW. Keep getting this error. Any ideas?
Recently started getting the same error message. I thought it was because I was getting to close to full or something that was trying to over fill the discs. Have tried EP and LP and this just started when I had a disc set to record to the end. I can't even open that one or finalize it. The rest do the same. They are working fine and when the error comes up, ZAP the disc is dead, no access.
I also tried putting the same disc into another Magnavox DVD recorder, still no access. These are both the most reliable recorders I've ever owned and I've had a number.
magnavox error message dvd "e 6 2a031000 can not record on this disc."
I suspect at this point, a batch of cheap Nexxtech DVDs. Also it's possible that it's a heat problem with the recorder? Once the disc goes into error mode, it's unreadable and all recordings that haven't been written to the TOC become invisible, but that time is forever lost on the DVD.
DVD is visibly (looking at recording surface) FULL but the supposed record time isn't used up. Data error. Discs reporting wrong size. Try a different brand of DVD.
Mar 28, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
DVD and VCR recorder with this product?
As long as you have Composite/SVHS Video Input, Usually a Yellow RCA Socket or a 4 pin Mini-DIN & red & White, AV (Audio Visual) RCA sockets on the machine, AND you can select an "External" input, then YES anything that can connect with this way will work.
Feb 10, 2010 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Connecting TV to DVD / VCR Recorder
Appreciate the direct "Ask Me".
I am assuming that what you intend to do is:
  • record a TV channel/program/show either on VCR or DVD;
  • while at the same time watching another TV channel/program/show directly on the TV.
Yes, but only if you are not using/needing a cable decoder box. To do this, the coaxial cable from your provider would have to be made to supply both the RF/ANT/CABLE IN of the VCR/DVD and the TV. To accomplish this, you would need a 2-way splitter. One input to the splitter, 2 outputs, one each for the DVD/VCR and the TV. The DVD/VCR would have to be connected to the TV using yellow, white & red RCA cables. To watch DVD, VCR and/or what is being recorded on the DVD/VCR, set the TV to Video mode. To watch regular TV, select the channels on the TV.
Good luck and Thank you for using FixYa.
Pls be informed that due to my current rank and rating, even a Helpful wouldbe detrimental to my status. Should this solution not address yourconcern, it would be appreciated if you could just not rate it at all. Cheers.
Dec 29, 2008 | LG RC797T
I cannot get my DVR4300 to go in to TV channel change mode while recording a program
Why not simply record a channel tuned into the vcr and use your tv remote to watch a channel tuned into your tv? that is how it is normaly done... don't forget a vcr/pvr/dvd recorder has it's own channels just like a tv does... just no screen of it's own the tv has of course it's own channels and in fact does not even need to be switched on in order for your recorder to record a program neither does the recorder need to be on to use your tv
Oct 14, 2008 | GoVideo DVR4300 DVD Player/VCR
SCREEN SAYS "SAFE" ?DO IDO TO GET RID OF IT???????/
To remove "SAFE" from the front display, using the remote control, press and hold "INFO" for 5 seconds until it disappears. This was probably acitivated while you stopped a recording which can trigger it, of you may have activated "Safe" by pressing the INFO button several times. This is to prevent access of the recorder by locking all controls. This is for the DVD Recorder/VCR combo VR320 and the 1st generation DvD Recorder DVR-130.
Even though this was a product I regret purchasing, it isn't as bad a people make it out to be. It works best with DV cable recording from 1 Hour Mini-DV tape camcorders to 1 Hour XP Record DVD mode. It is probable one of the best. Only issue I have is when you try playing a finalized DVD-R disc in another DVD player, there is a chance it might not work because of the Highest quality 1 Hour record mode. Standard is 2 Hour SP. You will have to burn an exact copy using DVD copy software on your computer to DVD-R. This will fix the problem.
May 31, 2008 | Samsung DVD-VR320 DVD Recorder/VCR
Magnavox ZV450MW8A can't record
Just set the channel to a non-premium channel (ABC, CBS, PBS, etc.) before starting the dubbing process.
Apr 20, 2008 | Philips Magnavox DVD/VCR Dual Player
Philips Magnavox DVD/VCR Dual Player Logo
360 people viewed this question
Top Philips Televison & Video Experts
ThaMp3Doctor
ThaMp3Doctor
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
