Question about HP Computers & Internet
HP Laptop - Characters Don't Appear, or Will Repeat, When Typing
When typing, randomly, some keys will either not produce a character or it will repeat the character. I've noticed it happening with the letters R, T, Y, U, I, C and sometimes the SPACE BAR.
Posted by Smokie Johnson on
Toby Lee
  • 409 Answers
Sounds like the keyboard needs to be replaced
Posted on Sep 07, 2012
5 Related Answers
listeur
Grant Cameron
  • 88 Answers
SOURCE: Keyboard typing wrong characters
turn off the keylock on boot- this is an option in the bios. also you might be able to use the fn key and turn it off manually
Posted on Nov 24, 2007
remmyjha
SOURCE: keyboard problems
when ever i want to make use of the backspace key to delete item it is not working what can i do
Posted on Jun 10, 2008
Anonymous
SOURCE: Keyboard Problem New NC10 - Incorrect Characters Appear
Press FN and F11 - will return keyboard to normal
Posted on Apr 15, 2009
Anonymous
SOURCE: bluetooth activates by itself, random letters appears when typing
it's a hw problem. when i using my easyport iv it doesn't occures. only when the display is turned up. after 2-3 hours of use i think it's overheating. (i tried to buy a waranty extension after i bougth the laptop, but acer said "it isn't available". i think thew know someting about this problem...) i bought it in Jan 2009, and the problem occured in Jan 2010. just after the warranty expired. wierd...
Posted on Mar 14, 2010
Anonymous
SOURCE: acer one aspire netbook - green keyboard characters
go to control panel...
click clock,language and region...
then go to keyboard and language tab...
click change keyboards.....
on the general tab...
look for english(united states) US on the add/remove keyboard list..
then press apply then press ok...
now the last step is restart ur netbook...
gudluck!
i hope it helps u...
Posted on Apr 08, 2010
The number keys to the right will not work, even after pressing number lock. suggestions?
Please open Device Manager and uninstall what is showing under "Keyboards". If you're unsure on how to perform these steps, follow this link:http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c03540049&lc=en&product=5450010&tmp...
Once you have uninstalled the keyboard driver, restart your notebook and it should automatically reinstall for you.
Let me know if this resolves the issue.
  • If the keyboard is not working in Windows, continue with these steps to uninstall and reinstall the keyboard software in Device Manager.
  • Click Start , then click Control Panel.
    Control Panel opens.
  • Click Hardware and Sound.
  • Click Device Manager under Devices and Printers.
    Device Manager opens.
  • Click View, and select Show Hidden Devices.
  • Double-click Keyboards, right-click the keyboard name, and then click the Uninstall button to remove the device from Windows.
  • Restart the computer.
  • The keyboard should now work correctly.
  • Your computer comes with several software programs that can test the keyboard for key or hardware failures. For more information, see the HP Support document Testing for Hardware Failures.
  • Notebook key presses are slow to respond
    If there is a short delay from the time a key is pressed to the time the character displays on the screen, the Filter Keys function might be activated. The Filter Keys function provides a greater range of key press options to fine-tune key delays and prevent inadvertent key presses. To disable Filter Keys and return to the default keyboard behavior, use the following steps:
    1. Click Start , and type keyboard in the Search box. Then select Change how your keyboard works under Control Panel.
    2. Remove the selection from Turn on Filter Keys. Then click Set up Filter Keys.
    3. Remove the check next to Turn on Filter Keys when SHIFT is pressed for eight seconds.
    4. Click Apply, click OK, and then close the Ease of Access Center.
      The keys should be more responsive.
    Pressing a notebook key once types several characters
    If two or more characters appear when pressing a key, use the following steps to adjust the key repeat delay:
    1. Click Start , and type keyboard in the Search box. Then click Keyboard under Control Panel.
      The Keyboard Properties page opens.
    2. Set the Repeat delay slider to Long. Click Apply, and then click OK.
    Notebook beeps while typing
    If the computer sometimes beeps while you are typing, Toggle Keys or Sticky Keys is active. Toggle Keys causes the computer to emit a beep when the Lock keys are pressed. Sticky Keys causes the computer to emit a beep when the Ctrl, Alt, Shift, or Lock key is pressed. Use the following steps to disable Sticky Keys and Toggle Keys:
    1. Click Start , and type keyboard in the Search box. Then click Change how your keyboard works under Control Panel.
    2. If selected, remove the check next to Turn on Sticky Keys. Then click Set up Sticky keys.
    3. Remove the check next to Turn on Sticky Keys when SHIFT is pressed five times.
    4. Click Apply, and then click OK to return to the Make the keyboard easier to use page.
    5. Remove the check next to Turn on Toggle Keys.
      If selected, remove the selection from Turn on Toggle Keys by holding down the NUM LOCK key for five seconds.
    6. Click Apply, click OK, and then close the Ease of Access Center.
      The beeps no longer sound.
    Wrong characters appear when typing, changing keyboard language, or Dvorak
    If the wrong characters appear when you are typing, or you are trying to use a different keyboard, use the following steps to synchronize Windows to the type of keyboard you are using:
    1. Click Start , and type region into the Search field. Click Region and Language from the search results.
    2. Click the Keyboards and Languages tab, and then click Change Keyboards.
      The Text Services and Input Languages page opens.
    3. Click Add.
    4. Select the keyboard you want to use, and click OK.
    5. From the Text Services and Input Languages page, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    6. Click OK. You can now use the new keyboard.
      If you find that the new keyboard service works correctly and you do not want to use the other keyboard, repeat these steps and Remove the keyboard service that you do not need.
    HP Notebook PCs Notebook Keyboard Troubleshooting Windows 7
    Aug 23, 2015 | HP Computers & Internet
    Stops typing mid line
    Type to the stopping point, press the margin release key space to the desired location, press R. margin key.
    Jan 08, 2014 | Olympia Mastertype 3 Typewriter
    Hi, my acer aspire 4930's keyboard not functioning correctly.. when i press letter "a" it appear as "A1" same as "Q" appears "Q1".. pls help me
    Hi.
    Try cleaning the keyboard with a clean, dry paintbrush just in case there is anything stuck under the keys. Once you have cleaned the keyboard try typing keys to see if it does the same thing. If the keys type as normal then you have resolved the problem.
    If the keys still type other characters along with the letter then there is a strong possibility that the keyboard needs to be replaced.
    This usually happens when something has been spilt on the keyboard causing it to type random characters or the characters directly above or below them.
    Seeing as the keyboard is a laptop keyboard you can use a wireles/wired keyboard or you can use the on-screen keyboard if you can't get the keyboard to work.
    If there is anything else please post back.
    Good luck.
    Jun 07, 2011 | Computers & Internet
    HOW TO ENTER special character like é SYMBOL ON NOKIA
    Inserting special characters on Nokia E61 and E70
    The most common special characters can be inserted by pressing the 'Chr' key and selecting the one you want from the pop-up grid.
    If there are rarer characters that you need, note that ANY Unicode character can be inserted by simply holding down 'Ctrl' and typing the number of the character concerned - it will appear at the current cursos position.
    Oct 11, 2010 | Computers & Internet
    My toshiba laptop is typing wrong characters but my wireless tevion keyboard is o k. Is there a solution to this ?
    Sounds like the laptop keyboard went bad and thats why its typing wrong characters. Best way to verify this is to use a USB keyboard on the laptop, if the USB keyboard is typing the correct keys then you know the laptop keyboard is bad. If the USB keyboard is typing the wrong keys as well then you know its a setting in windows that is causing the keys to type wrong characters.
    Apr 28, 2010 | Toshiba Satellite P105-S9312 Notebook
    Ti 83+ calc has garbled random characters when typing in #'s
    You may have to force the calculator to boot up so that you can reinstall the OS. Details are in the article . Read the part on Ti83Plus family.
    The article contains links to additional pages.
    Hope it helps.
    Oct 11, 2009 | Texas Instruments TI-83 Plus Calculator
    Typing any key on the keyboard produces multiple
    hi Jeff.
    go to this link should show you how to do a reset of your laptop.
    How to Reset Your Computer .
    or this link.
    laptop basic reset Google Search
    Nov 18, 2017 | Toshiba Portege M205-S810 Tablet PC
    Toshiba tecra s2 keyboard starts skipping typed characters and stalling
    there may be a pressed key in your key board, but pls chcek the key board with keyboard tester free software to identify pressed keys.
    pls remove the key board cap carefully and clean
    Apr 29, 2017 | Toshiba Tecra S2 Notebook
    Computers & Internet Logo
    Top HP Computers & Internet Experts
    Lee Hodgson
    Lee Hodgson
    Muntejaya Ginting
    Muntejaya Ginting
    efs_perpends
    efs_perpends
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
