Question about Texas Instruments TI-84 Plus Calculator
Polar to rectangular conversion working incorrectly
When I try to convert from polar to rectangular (320e^(-45i)) i get a result of 168.103-272.289i when I should get 226.27 - 226.27i. This is weird because when I do the command (226.27 - 226.71i) >Polar, it will give me the correct answer of 320e^-45i. When I do (168.103-272.289i) >Polar it gives 320e^-58.3i. Is there anyway to fix this? I was pretty sure my calculator was doing this correctly before, but it won't anymore.
Posted by balisticcmv on
Stevan Milanovic
    Sergeant:
  • Texas Instru... Expert
  • 267 Answers
At first, Rect and Polar are a display-format instructions, not a conversion functions. Polar instruction displays complex value in rectangular form a + bi. The complex value can have any complex form. However, an r*exp(i*theta) causes an eror in Degree angle mode according to the TI avowal. See captured images below
polar to rectangular conversion working incorrectl - 9_6_2012_10_12_22_pm.jpg
Posted on Sep 06, 2012
1 Related Answer
k24674
  • 8091 Answers
SOURCE: I'm trying to do sin
It is very likely that when you change the angle unit, you are not saving the changes made.
After you finish changing settings, use the TAB key repeatedly to move cursor towards the OK button at the bottom. If you do not confirm changes by clicking OK, they will be lost.
You can also make the changes the default ones by clicking the Make Default option.
Posted on Jul 29, 2011
How to covert from polar to Rectangular
Let use an example to convert from polar to rectangular. There may be other ways to do it on this particular calculator, but this should work on all calculators.
Let's use 20 degrees and 5 units for our polar.
Sin 20 degrees = y/5, cross multiplying we get y = 5 sin 20 degrees.
Similarly, Cos 20 degrees = x/5. Cross multiplying we get x = 5 cos 20 degrees.
Thus, I get (1.71, 4.70) as the rectangular coordinates of the point.
Good luck.
Paul
Nov 06, 2015 | Canon F-603 Calculator
Conversion of polar to rectangular form and vice versa
Conversion of polar form to rectangular:
  • Switch to CMPLX mode: [MODE] [2]
  • Enter complex number in polar form, e.g. r = 3, θ = 42°: 3 [SHFT] [(-)] 42 [=]
  • Switch to rectangular view: [SHFT] [2] [4]
Conversion of rectangular to polar:
  • Enter complex number in rectangular form, e.g. real part = 2, imag part = 3: 2 [+] 5 [ENG] [=]
  • Switch to polar view: [SHFT] [2] [3]
Jan 12, 2011 | Casio FX991ES Scientific Calculator
How do I convert between the rectangular and polar form of a number with imaginary values? i.e. I want to take the number a+bi and convert it to polar D<(angle) and vice versa.
Use the >Rec and >Pol commands. They're in the Complex number menu, accessible through 2nd [CPLX] MORE.
[CPLX] is the shifted function of the 9 key.
Dec 10, 2010 | Texas Instruments TI-86 Calculator
Converting between Forms When working with phasors it is often necessary to convert between rectangular and polar form. To convert from rectangular form to polar form: M = sqrt{A^2 + B^2} f =...
You can switch the display mode for complex numbers by pressing SHIFT MODE down 3 and picking one. This will display the current result in the selected mode.
You can also override the current display mode and specify the format. Add these keystrokes at the end of a calculation: SHIFT 2 then 3 for polar or 4 for rectangular.
Nov 24, 2010 | Casio FX-115ES Scientific Calculator
What calculator would you recommend for polar and rectangular formula's?
Are you serious?
No calculator purchase should be solely based on such a trivial matter.
But if you are looking for a very good scientific calculator, I would suggest the new Write View EL-W506/W516/W546 calculators by Sharp, or the FX-115ES/991ES Natural Display by Casio.
With these calculators you can see what you enter displayed as in textbooks. Naturally, they all do coordinates conversions from Polar to Rectangular and from Rectangular to Polar.
Jun 17, 2010 | Casio FX-115ES Scientific Calculator
I've read that the Casio fx-115ES does a great job working with complex numbers, but I haven't found it to be so simple. I am looking for an easy way to convert from rectangular to polar form and back. It...
You can perform coordinate conversions in the COMP, STAT, MATRIX and VECTOR Modes.
Angle unit may be in either degree or radian.
To convert from rectangular to polar, (SQRT(2)/2,SQRT(2)/2)
Press [SHIFT] [+] (Pol)
Screen displays Pol(
Type in SQRT2
Use right arrow to move cursor out of radical
Type in /2 [SHIFT] [,]
Type in SQRT2
Type in /2
Close the right parenthesis
Screen displays Pol (SQRT2 /2, SQRT2 / 2)
Press [=]. Display echoes the command on top line and result in bottom line as r=1, theta =45, (if unit is in degree) or theta = 0.7853981634 if unit is radian.
To convert from polar to rectangular coordinates
Note: You cannot use the answer memory to convert back to rectangular because the calculator will use the r-value only. So you will have to enter the radius AND the angle.
ex: Rec(1,45)
Angle must be in degree
Press [SHIFT][-] (Rec)
Screen display Rec(
Type in 1 [SHIFT] (,) 45 [)] [=]
Calculator displays X=0.7071067812, Y=0.7071067812
If you press the SD key hoping to convert the decimals to radicals, the calculator will not do it.
As to the "confusion", I have found none.
After you finish entering the argument of a square root, use the right arrow to move cursor out of under the root symbol to signify that the argument is complete. If you use a left parenthesis inside the root, you must insert the matching right parenthesis inside the root, then move cursor outside the root.
This is how the calculator behaves, and I am not expressing an opinion on how simple or complicated that is. I assume that to make full use of the calculator capabilities, one has to converse with it, using the syntax it understands.
Mar 31, 2010 | Casio FX-115ES Scientific Calculator
TI-84 has problems converting between rectangular and polar. is there a fix for this?
The conversion from rectangular to polar coordinates requires the calculation of an angle . If the angle unit that the calculator is configured for is different from the one you have in mind, you get (not erroneous results) but unexpected ones.
If the angle unit under [MODE] is radian, the angle you get in the conversion is in radians. Similarly, if the angle unit is degree, the angle obtained after coordinate conversion is in degrees.
Check your angle unit and restart your calculations.
Feb 19, 2010 | Texas Instruments TI-84 Plus Calculator
Can you show how to convert pola to rectangular o
To avoid errors make sure that the angle unit is THE ONE required by your problem. To verify or to change the angle unit press [SIFT][MODE] and select [3: Deg] for degrees, [4:Rad] for radians, or [5:Grad] for grads.
Convert from rectangular to polar
[SHIFT][+] (Pol) . Screen displays Pol(
You enter the X-coordinate, and the Y coordinate separated by a comma, then you close the parenthesis and press [=].
Exemple: Polar coordinate of the point (1,1)
Pol( 1, 1) gives
r=1.414213562 (square root of 2)
θ=45
Here is how you enter it
Press [SHIFT][MODE][2:LineIO]
[SHIFT][POL] 1 [SHIF] [,] 1 [)] [=]
The screen displays
Pol(1,1)
r= 1.414213562
θ= 45
Convert from polar to rectangular coordinates
Rec ( radius, angle) =
Exemple: Recatngular coordinates of (r=3, θ=60°)
[SHIFT][Rec] 3 [SHIFT][,] 60 [ ) ] [=]
The screen displays
Rec(3,60)
X= 1.5
Y= 2.598076211
Hope it helps.
Nov 14, 2009 | Casio FX-115ES Scientific Calculator
How to convert polar to rectangular form
Press [MODE] and select [1:COMP]
Press [SHIFT][MODE] and select [3:Deg]. You can also use rad if the angle you are given is in radians.
To start the conversion
Press [SHIFT][-] (Rec) screen displays Rec(
Key in the radius r , ex: 3 screen displays Rec(3
Press [SHIFT][)] (,) to enter comma separator Rec(3,
Key in the angle in degrees, ex: 57.3; screen displays Rec(3,57.3
Press ) to close parentheses; screen displays Rec(3, 57.3)
Press [=]
Screen displays
Rec(3, 57.3)
X=1.620720961
Y=2.524532346
X and Y are the values of the coordinates.
If angle is in radians, [SHIFT] [MODE][4:Rad] the command
Rec(3, Pi) gives X=-3, Y=0
Hope it helps
Oct 18, 2009 | Casio FX-115ES Scientific Calculator
Polar/rectangular
For a TI-86
Converting rectangular to polar
Press "2ND" and then "MORE" for the MODE screen
Highlight PolarC and press "ENTER"
Quit that screen.
Now ready to go.
A example of converting 5+j6
Enter "(5,6)" in the calculator and press "ENTER"
Should get (7.81024967591*angle*50.1944289077)
Converting polar to rectangular
Highlight RectC and press "ENTER"
Quit that screen.
Now ready to go.
A example of converting 5*angle*35
Enter "(5*angle*35)
Should get (4.09576022145,2.86788218176)
Note
*angle* is the symbol when you press "2ND" then ","
Note 2
To round the an decimal places press "2ND" then "MORE" for the MODE screen and on the line that says float, choose a number on that line for the number of decimal places you would like to have.
More can be found at
http://docs.google.com/gview?a=v&q=cache:nAC57BtC6IIJ:myweb.wit.edu/khabaria/ELEC195_files/ti86cplx.pdf+ti-86+convert+to+polar&hl=en&gl=us
Dec 02, 2008 | Texas Instruments TI-86 Calculator
Texas Instruments TI-84 Plus Calculator Logo
733 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
