The pcb has a jack plug socket soldered to it. Most chargers now seem to have "neutrix" plugs and ones with jack plugs are rare as hens teeth and very expensive! If I use a 3 stage charger can I bypass the pcb and fit a neutrix socket? I'm assuming that the "interface" board is basically fulfilling the function of voltage control and switching function that the 2 (or 3) stage chargers already have.
SOURCE: I needto replace the battery charger on my Rascal 600F scooter
Hi. Most chargers with only two wires, have a small bridge wire from the
black ( negative ) wire to the middle terminal of the connector. This disables the controller while the machine is charging. The charger will still work without this bridge wire, but the scooter will still operate normally.
There are a few different chargers around that have an internal relay that disables the scooter, but these chargers are normally "on-board" chargers.
Good luck. Neil.
SOURCE: Have Shoprider Sovereign 4 Scooter.
The batteries are weak - either they are worn out or they are defective. They will have to be replaced.
SOURCE: Hi, fitted my scooter with two brand new 40 amp hr
What type and what voltage were the old batteries removed from the scooter?
Testimonial: "Thank you for the help, - the link didn't work but i'm slowly getting to understand things now."
SOURCE: old chair battery charger 2904-24 automatic 3
Here is a link to 2 pages which stock parts for wheel chairs and power scooters.
http://www.monsterscooterparts.com/jet3ultra.html
http://www.southwestmedical.com/replacement-parts/pride-mobility/jet-3-ultra
Sorry couldnt get you the exact part number as i dont have the exact details of which unit you want it for. But most of the pride mobility range use the same battery charger.
Hope this solution has been helpful?
Thank you for visiting FixYa.
