Question about FreeMotion Tt30 Incline Trainer
We have a Free Motion Tt30 Incline Trainer making a loud noise that sounds like a bearing going bad, then the noise stops. Do you have any repair suggestions?
The first few minutes when the trainer is used is when the noise is loudest. The noise started about a month ago. Can you tell me how to care for this situation?
Posted by Linda Higginson on
ernesto cuadra
    Top Expert:
  • FreeMotion Master
  • 12,223 Answers
1) Lube the machine see the video and use the common sense, this happen because the lack of maintenancae according with the instr. manual. Shut down the machine for to protect the electronic system.
2) Lube the rollers bearing too, very well.
3) Test the input voltage motor, if there are the motor NEED repair.
4) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty. see the block diagram.
God bless you
We have a Free Motion Tt30 Incline Trainer making  - 9_7_2012_11_57_29_am.gif
Posted on Sep 07, 2012
My front tire makes a loud whining/horn like sound when it is in motion, what can be the problem?
Either bad brakes on that side or a bad wheel bearing.
HOPE THAT HELPS
Dec 16, 2014 | 2014 Dodge Avenger
My 2009 nissan altima has a loud growling sound
This could be one of two things. We will first start with a wheel bearing. When you are driving, does the growling noise get louder as you go faster. Some times is will sound like you have a helicopter flying beside you depending on how bad the bearing is. The second thing that could be causing the growling noise is your transmission. There are also bearings inside your transmission that could be causing the noise. If you have a cvt transmission, you have a 120,000 mile warranty and can have it repaired at no cost to you. You will just have to go to a nissan dealership.
Feb 19, 2014 | Nissan 200SX Cars & Trucks
Tt30 is stuck at 3% incline and will not speed up or slow down. It also beeps continually and displays SB for about 5 seconds when first turned on. I tried the recalibration procedure and it does not...
please RUN the software calibration for easy diagnostic and fix it.
go to HOOD cover motor, and follow the steps, or ready your owner manual
God bless you
Oct 15, 2013 | FreeMotion Tt30 Incline Trainer
Incline works but belt wont move
see the video and lube deck belt+rollers bearings
God bless you
Feb 03, 2013 | Free Motion X3 Incline Trainer Treadmill
Front end makes loud noise while driving over 10mph and gets louder and hums down when i stop
It sounds like you may have a wheel bearing/ hub assembly starting to go bad...You can check this by jacking up the front end and checking for slight play in each wheel when you try to move tire in a side to side,and up and down motion basically But you just want to use a wiggle motion...you should be able to feel a bit of excessive play in the side which is going bad...One side will be tight with no play,and the other will have some play if the wheel bearing hub assembly is going bad...
Nov 22, 2012 | Cars & Trucks
I have a 680 proform trainer and the motor is very very loud. what do I need to do to fix it?
Try to put some oil in bearing of motor. For oiling the motor bearing you have to open the top cover. Be sure to remove the power before opening the treadmill. Normally bearing makes noise may be because of insufficient lubrication Or the bearing itself is faulty. Check is the lubricating reduces the noise or not. if not then you have to call for a repair man to change the bearing or replace the motor. un the following link you can fin the motor for your treadmill. Be sure that the power is remove before opening. because all treadmill's motor control circuits are live if there is power.
Motor
Ajin
Jul 21, 2012 | Proform Power Series 680 Treadmill Fitness...
Whirlpool washer making loud noise when spinning
It sounds like you need a bearing job. The bearings in the back half of the wash tub go bad. and the washer gets loud .It's an expensive repair. I hope this helps
Jul 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My check engine light is on. There is a squeaky cricket noise when the car is in motion; it is not a loose belt. I don't want to take it in and be overwhelmed with major engine problems. Any ideas what it...
for the check engine light:
-you can go to auto zone and have them hook it up to the computer for free!!!!!
for the squeaky cricket noise:
-could possibly be a wheel bearing starting to go bad, or possibly a wear sensor on the brakes....
that is only if it makes the noise when the vehicle is in motion.... if the sound is there while it is sitting still, then you could have a pulley bearing going bad... hope this helps.... please rate this...
Apr 12, 2010 | 2002 Mercury Mountaineer
Washer model PAVT244AWW agitation noise
Sounds like the motor is going bad. It will only get louder before it finally stops. There is a device that assists the agitation motion that may be bad or is going bad.
Dec 01, 2008 | Maytag PYE2300AY Electric Dryer
FreeMotion Tt30 Incline Trainer Logo
346 people viewed this question
Top FreeMotion Exercise & Fitness Experts
Marvin
Marvin
ray gallant
johobikes
johobikes
Level 1 Expert
Are you a FreeMotion Exercise and Fitnes Expert? Answer questions, earn points and help others
