Bosch GML 24V-CD Power Box Logo
Posted on Sep 06, 2012
No display or radio - Bosch GML 24V-CD Power Box
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 22, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
564
Points
I know that with the older bosch radio's PB 10-CD there are two internal fuses that 250V 2AMP. You have to remove four allen screws on the front of Bosch powerbox and then remove the four phillips screws one on each side. This will allow front of radio to be pulled out about 5 inches witch will give you enough access to check/change fuses. Fuses are held in place with plastic cover that has one small phillips screw holding it in place. Hope this helps
Capacitors to fix dim display wave radio AWR1-1W
Vacuum fluorescent display is worn out .. there is no repair. Replacement is the only cure.
Don Miller, CET
Bose Wave Radio Repair
[email protected]
2answers
Unlock ford car radio. have code.
can you give the number or name of the model
tip
Delco Radio displays and climate control displays remain dark, all GM
Symptom is radio diplay or controls don't light up, Delco CD radio's and Bose preminum sound radio/CD players. Models all GM cars and trucks 1990's to presnt.
This problem is caused by two tiny burnt out bulbs behind the LCD display thay are soldered to the circuit board behind the radio LCD display and can be replaced, this requires the radio be removed and the housing taken off and the front display un-clipped, you will need a low temperature solder pencil and thin strand solder the bulbs are available from Radio Shack, the part number is 272-1092, this is a 2 pack of miniature 12 Volt 60Ma bulbs. This radio display bulb is used in may car models, this bulb also repairs climate control displays as well as other low light displays like switches
Can the radio display be set to display the current time only?
Some radio allow this function,just read it's Setting/Menu carefully.
How to set and remove alarm set
Turning on/off the alarms
To turn alarm 1 on/off, follow these steps:
  1. Turn the system off
  2. On the radio, repeatedly press the Alarm Mode button until the desired alarm mode indicator below "Alarm" is displayed. The music note indicates radio and the sound waves indicate the alarm tone. If no icons appear on the display, that means the alarm is turned off
wr_alarm_set_icon_both.gif Radio and tone
Radio only
Tone only
Alarm off
To turn alarm 2 on/off, follow these steps:
  2. On the radio, press and hold the Alarm Set button. "Alarm" flashes on the display
  3. While holding Alarm Set, press the Alarm Mode button once. "Alarm 2" flashes on the display
  4. Release Alarm Set, and repeatedly press Alarm Mode until the desired alarm mode indicator above "Alarm 2" is displayed. If no icons appear on the display, that means the alarm is turned off. The "Alarm 2" indicator will continue to flash on the display for 10 seconds. When the flashing stops, alarm 2 is set
wr_alarm2_set_icon_both.gif Radio and tone
Radio only
Tone only
Alarm off
8helpful
2answers
I have lost my radio code for my ford can you help.
Late Four Digit Ford Radio Codes (no SELECT button) ie. Ford 3000 Traffic, 4000RDS, 5000RDS, 6000RDS, 6006E, etc Switch the radio on and the word CODE should appear in the display Repeatedly press button 1 until the correct first digit of the code is displayed.
Repeatedly press button 2 until the correct second digit of the code is displayed.
Repeatedly press button 3 until the correct third digit of the code is displayed.
Repeatedly press button 4 until the correct fourth digit of the code is displayed.
Once the code has been correctly selected on the radio's display, press button 5 to enter. If "LOCK 10" is shown on the display, please contact us for guidance. If the display shows "LOCK 13" code entry will not be possible, and the unit will need to be electronically decoded by a car radio servicing specialist. Early Four Digit Ford Radio Codes (units with SELECT button) ie. Ford 2005, 2006, 2015, etc Switch the radio on and the word CODE should appear in the display. If CODE does not appear immediately, press the SELECT button momentarily, and CODE should then appear on the display. Repeatedly press button 1 until the correct first digit of the code is displayed.
Once the code has been correctly selected on the radio's display, press the "SELECT" button to enter. Three Digit Ford Radio Codes ie. Ford 2000, 2001, 2005, 2007, etc Switch the radio on and the word CODE followed by three dashes should appear in the display. These three dashes should be flashing. Enter the three digit code by repeatedly pressing station presets 1-3 until each digit is correctly displayed, followed by preset 4 to accept the code. The unit should then function normally. If, after switching the radio on, the three dashes do not flash, then 3 or more incorrect code entries have been attempted. If a number 10 appears in the display, then ten incorrect codes have been tried and the unit will need to be decoded by a car radio servicing specialist.
Radio lights, steering wheel radio controls, and HUD not lighting
well, this morning they are fine, all i did was checked all fuses that had to do with illumination and radio. none were bad so no replacements were made, and now it works. wish i knew what i did.
3helpful
No radio text display on vauxhall corsa
model cdr 2005 radio/cd player works fine except there is no display above where the radio station2_bing.gif/cd track number is supposed to be displayed. I have time and temperature as normal
Display hard to read
My radio was dropped and parts of the display disappeared, but the display did not break. Unless you have some background in radio repair, DO NOT attempt this repair! If you do, it is at your risk, or the risk of damaging your radio! I disassembled the radio and found the display. There are 2 "rubber strips" that fit next to the LCD. I cleaned and reseated the strips and display about 3 times before getting it right. AGAIN, unless you know what you are doing, and can solder on circuit boards with a proper pencil iron, don't even contemplate it! Let someone who can do it.
Top Bosch Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Bosch Audio Player and Recorder Expert? Answer questions, earn points and help others
