SOURCE: Bosch Diswasher not draining
Soyben, you need to check to see if either the drain hose or syphon break at the sink is clogged. The drain motor on this model is not a bilge pump that will remove water from the base. Therefore Im leaning on a restriction somewhere. Other than that you may have to check for debris in the drain sump. Check these areas out first...Catriver...post back
SOURCE: Bosch diswasher
check heater element for open circuit, if the dishwasher fills and empties and wooshes the water round, there is little else to go wrong
SOURCE: bosch dishwasher SHU66C02UC - Rinse Agent issue
Does soap draw open at right time?
Same solenoid opens soap draw as injects rinse aid.
Turn up hardness counter ?
Any blockages in dispenser unit its-self?
OTHERWISE CALL IN THE PROFFESIONALS !
SOURCE: The rinse agent light is on and the water will not spray out
NO WILL STILL WORK IS ONLY A FLOAT SWITCH TO WARN YOU,HOWEVER RINSE AGENT DOES AID THE DRYING PROCESS SO WITHOUT YOURE DISHES WILL BE WET AND SMEARY
SOURCE: bosch diswasher will not stop washing, goes to
The reason your dishwasher is displaying a "1" is the control has detected a heating error. The error code is displayed by the number "1". Here`s the most likely reason why it has detected the error...
Even though your water appears hot, it's not hot enough. The issue with your Bosch dishwasher likely lye`s within`the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ). This is why it runs forever unless pressing the two buttons for "cancel".
To repair your unit It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board. This will be one of the pins from the heater relay, hence the unit sit`s at "1" ( because it can`t heat to advance or until canceled ) trying to heat the water.
**Further to this, if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...although Bosch recommend`s replacing the control and I don`t pretend to speak on there behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)**
**Please disconnect the power before attempting any service to the dishwasher. If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau, to service your machine.**
Hope this answer`s your question's, let me know if I can assist you further. Thank`s for visiting "fixya" for your repair inquiries. Please take a moment and rate this solution to it's helpfulness to you and leave a testimony if you're satisfied.
Good luck.
macmarkus :)
