SOURCE: Sound Problems
are u runing dvd player to tv 1st audio and video and eco meens tv is on with sterio same time erther one or other run the the dvd audio to dvd in on sterio and video cables to tv only dont use souind on tv just sterios if u want tv sound tooo use tvs rca outs back into sterio on a ch tv in ok
SOURCE: No Video or Audio on HDMI on Sony STR-DG800
I dont have the exact model you do, but on my sony receiver I have to enter the setup menu and define where the input is for the device I am using. For example I have to tell the receiver to use the optical audio input instead of the RCA Stereo. Otherwise its on default.
Also, you do know this model of reciever offers only pass-through audio on HDMI? that means no surround sound!!! Thats really silly but thats the specs for this model. To get surround you'll have to use optical. otherwise , with HDMI through this sony you are adding an extra component to tyour system with no benefit other than maybe power amplification.
SOURCE: Can't get Playstation3 sound through the STR-DG800 using HMDI.
Do you have your ps3 connected to the TV with HDMI and then audo cables from the TV to the receiver? If so, you need to make sure you change the audio settings on your TV to surround sound.
SOURCE: Sony Model: STR-DG800
You've got a short in one of your speaker wires either at the receiver (most common) or at the speaker itself. you should only have a 1/2" of each side of the speaker wire stripped to put on each terminal, and when you strip them, twist them so there are no frays in the strands that will touch the other terminal. The receiver is protecting itself from harm. Turn it off then disconnect all speaker wires, examine each wire carefully before reinstalling, then turn the receiver back on. If it still says protection, look at each speaker and reconnect your wires the same way. If you still have a problem, disconnect the wires again at the receiver and turn on, at this point, if it say's protection, it needs to be serviced. Hope this helps
