SOURCE: The scanner will not recognize a bad barcode. the
There are many factors that can make a barcode a "bad" barcode. Moving the barcode closer or farther from the scanner won't solve many of the attributes that make a barcode "bad". It may have a wrong check digit. It may be the wrong type of symbol, or the scanner may not be programmed to see this type of symbol. It may be printed in a color the scanner has difficulty seeing. The substrate or the bars may be too reflective. The scanner may be at the wrong angle (not just distance) from the barcode. Most scanners need to see the barcoce at about 60 degrees--90 degrees is always a problem.
Can you email me a pdf of the barcode? I may be able to identify the problem from that.
SOURCE: I have installed a scanner
check the cable and i would advice you try installing the device software again.I hope this solution has been helpful.
SOURCE: Is there a Windows 7
Hey David, According to the fujitsu website, 4120C is NOT supported in windows 7 at all... :-(
Sorry!
SOURCE: I am facing frequent paper jam problem with
if it has a manufacturing date of march of 2009 thru august of 09, then it has a defect with the glass mounting on the base assembly. unfortunately, i used to work fixing these things all day long. What is the manufacturing date of the scanner? See the rear label in the back to find out.
