Motherboard
SOURCE: Motherboard for Toshiba Satellite P30
hi friend check this website out here is a price and repair company you could send it to. link.http://product.pelltechnology.com/Toshiba_Satellite_P30-S701TD_Motherboard_Replacement.asp
copy and paste
SOURCE: i have a toshiba satellite p305d-s8828 laptop and
Since you have measured the voltage on the motherboard I must presume you are saying there is no power "indicator light" on computer. If this is not the case please clarify. If the light is absent please test the battery as these laptops are not designed to work without a battery or with a dead battery. Operating without a battery can spike the motherboard or other components and cause failure due to overvoltage. If you do have a power indicator light then next observe whether the bootup is proceeding with a beep after the POST (power on self test) and whether you can hear the movement of the hard disk drive... possibly indicating failed LCD display or display drivers/setup. Press F8 after the POST beep to get to safe mode display drivers.
SOURCE: Toshiba Satellite L305-S5900. No power indicator light.
sorry there is no fuse that i know of on the satellites it sounds like a motherboard issue see if it can be warranty repaired by the manufacturer
Does anyone know the actual part number for this or where I could get one? Thanks
