Im in need of some kind of speaker brackets, right?
No brackets are necessary...I believe you are talking about replacing the rear speakers located in the rear wondow shelf...Of course the speakers mount underneath the window inside the trunk...You can remove the rear seat and pull the interior trim back to view the top side of the speaker mounting...The opening is already cut for the 6X9 speaker...You can mount the top underneath the window cloth material like the factory did, or no need to remove the interior cloth if you use new top speaker covers, usually come with the speakers. Hope this helps.
SOURCE: The windows in the 95 oldsmobile cutlass ciera won't work at all
maybe the wire is severed where the door (drver dr) pivots. thats what was wrong with mine. there is a rubber boot with crinkles in it that hold all the wires together. you can also try replacing the switch board that controls the wndws on the drvr dr. hope that helps.
SOURCE: how to change a starter in a 1992 oldsmobile cutlass ciera
disconnect battery,three bolts hold it to bell housing and two wires ,one is the feed the other activates the solonoid Easy job to do but dirty dirt grease and muck
SOURCE: 1995 Oldsmobile Cutlass Ciera SL 2.2 head bolts
you have long bolts and short bolts, long bolts go in positions 1,4,5,8,9 - short bolts remaining positions, all long bolts go in back of engine, toward fire wall or front of dash, those are positions starting at passenger side to drivers side, 8,4,1,5,9, so 1 is in the center position, 9 on drivers side. short bolts in front, positions passenger side 7, 3, 2, 6,10, stud is in position 10. Tighten bolts in sequence, starting at 1, long bolts get 32Nm, short bolts get 29Nm, next pass torque all to 58NM, than final pass add an angle of 100 degrees, little more than 1/4 turn with wrench. Bolts should have 11.9 on head, the tightening specification is called a torque plus angle to yield, that is why in your gasket kit is tells you to replace the bolts, it is recommended. I know, because I am the GM Manager for fastening engineering. Hope this helps
SOURCE: what temperature does an 1995 oldsmobile cutlass
fan turns on at approx. 225 & will turn off at approx 210
SOURCE: Changing spark plugs on a 1995 Oldsmobile Cutlass Ciera
ALL YOU NEED IS 3/8 RATCHET WITH A 5/8 SPARK PLUG SOCKET.YOU NEED EXTENSIONS AND UNIVERSAL JOINTS TO GET TO HARD TO REACH PLACES.YOU NEED A SPARK PLUG GAUGE.YOUR SPARK PLUG GAP SETTING WILL BE. 0.060 THAT WILL BE FOR THE 2.2 AND 3.1 ENGINES.
Testimonial: "Thank you very much for your advice and time!"
