Question about Epson PictureMate Office Equipment & Supplies
My epson printer pm245 asks service required
Service required?
    New Friend:
I cant print coz of my printer (pm 245 Epson Printer) blinking 2 red light. Printer dosnt ready. It say-Service required. how can I release this problem. Plz tell me.
Posted on Sep 07, 2013
    New Friend:
Service required problem
Posted on Apr 12, 2014
5 Suggested Answers
Anonymous
SOURCE: EPSON PRINTER R22O
display This massages Parts inside your printer are near the end of their service life.
See your printer documentation.
Posted on Apr 28, 2008
Anonymous
SOURCE: Epson rx 500 "service required"
Press on off, load expulsion, byw,color and stop all at the same time, wait until it is on. then press color and then shut down.
Posted on Jun 25, 2008
Anonymous
SOURCE: Epson Sylus Photo RX600
press the on, stop, color & b&w buttons at same time and hold them down for awhile......seams to reset everything....good luck
Posted on Sep 15, 2008
gwbm
Gerry Millward
  • 353 Answers
SOURCE: epson c62 printer say's parts need replacing, service required
These symptoms usually mean the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from:
http://www.ssclg.com/epsone.shtml
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (C62), then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. Check the current count value - if it is greater than the limit shown it will confirm this is your problem. Then choose reset to set it to zero. You will need to fib about having changed the waste ink pads! Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help. It is a pretty simple job once someone explains how to get the case apart!
If this solution helps you, please rate it; if it doesn't, please provide further information by posting a new comment.
Posted on Apr 14, 2009
I have a problem with my epson pm245 there is an error a printer error has occurred.see your documentation. how can i solve it?
What have found is that Epson has some very good hardware as far as printers are concerned. I think that the best thing to do is log onto the http://www.epson.com and locate the tech support and drivers section; type In your printer number and they will provide you with the correct drivers.
If you get really stuck, they have a very good and patient support group.
Hope this will help
Al
Feb 15, 2017 | Epson Office Equipment & Supplies
Epson pm245 resetter
The Epson pm245 ink pad are at the end of their service life
Aug 26, 2013 | Office Equipment & Supplies
Epson pm 245 error
Epson pm245 red color not found how to solve it
Mar 24, 2013 | Office Equipment & Supplies
HI MY NAME IS RALPH I HAVE A PROBLEM WIHT MY PLOTTER EPSON 9600 IN DISPLAY SAY SERVICE REQ 001002D WHAT IS THIS???????
Hi mofeed1400 ,
the message " SERVICE REQ 001002D " simply means that some service is required.
call the service centre for " Epson " in your area and get it serviced.
or take your printer to the store where you bought it along with your receipt and ask them that you printer is in need of service.
i hope this helps.
May 16, 2011 | Office Equipment & Supplies
Service required for EPSON STYLUS R230
http://www.efillink.com/Support/HowToWasteInkDrainR200.html
Sep 25, 2008 | Epson Stylus Photo RX700 All-In-One InkJet...
1,099 people viewed this question
Top Epson Office Equipment & Supplies Experts
Thomas F. Schneider
Ekse
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
