Battery on main mic leaked into the board inside. no audio coming out of the mics. everything else works. do i need to replace the board? where can i get a new board for a reasonable price? in metro manila, philippines plese. please help.
Before starting to search for a replacement board do the following steps:
1-take out the batteries.
2-wash your board with water and a little detergent using a tooth brush.
3- use a hair dryer to dry your board .
4- leave your board in a warm place(preferably in sunshine) for a few days to make sure that no moisture is left on the board.
After you have done all this you may find your mic working normally .If your mic is still not working ,using a magnifying glass search for loose solder joints.
hope this helps you.
SOURCE: No sound comes out of the mic....
there's not really any way to tell whats wrong with it apart from it seems to be damaged internally.. if you have the receipt and its still under warranty i'd take it back and not mention the drop!
Jay.D Bsc Music Technology
SOURCE: Entertech mic ed-9000--Mic stopped working
Could be the wiring in the RCA cable.
Swinging mike to and fro can wear through the power wiring inside the cable.
I'm on my 3rd cable.
Manufacturers have said they recognise this is a common fault with product but it seems they are not taking any steps to rectify.
I found that using the mike with batteries sometimes works.
If you get a new cable may be a good idea to reinforce the top 12 - 18 inches of the cable to avoid same problem in future.
SOURCE: indian chips for entertech
Yes my mic is still not working. Hw much would you be willing to pay?
SOURCE: the green light just keeps blinking and it doesn't
Did you find the solution, I have the same issue and the Leadsinger company is not a verry serious company no one knows about this and no one can help! Thanks Cathy
SOURCE: I have a EnterTec Karaoke
Make sure the microphone is turned on and the batteries are brand new. Next, make sure the microphone is plugged in securely and turn the mute switch off on the microphone. If it is still not working then click on the link below and send it in for a free replacement:
http://www.magicsing.org/Contact-Us/Magic-Sing/
http://www.magicsing.org/Enter-Tech-Magic-Sing-Troubleshooting-Tips.html
I can help you on your problem to replace ed2000, this my #09178796368
