Question about Sharp R-1610 Microwave Oven
Wrecking for magnets - Sharp R-1610 Microwave Oven
Posted by mike leeke on
William Miller
  • Sharp Master
  • 9,179 Answers
If the oven has not run for a few minutes and is not plugged in, there is very little chance that the high voltage capacitor has any charge stored on it.
If you're still concerned about getting a zap that might make you get a cut when you pull back your hand on the sharp metal inside the microwave, you can discharge the capacitor. Here's how.
The magnets are in the magnetron.
Other questions? See the FAQ here.
Posted on Sep 06, 2012
Testimonial: "THANKS Very Much Mate,I've got the magnets, & no dramas, Mick."
  • mike leeke Sep 06, 2012
    Thank You Mr. William Miller, your advice is spot on, & I now have my magnets. Cheers, M. L. Australia.
Microwave says the door is not latched. One time we got a diagnostic readout, and it stated the Magnet had a problem. We would like to be sure but can not seem to get back to this magical screen.
What brand and model number? It probably referred to Magnetron, not magnet, as I have never seen a sensor or test for the magnets themselves. If it is reading the door as not latched you may have a problem with a door switch or the arm from the door not pushing down on the switch properly to close the switch.
Sep 22, 2017 | Microwave Ovens
Wont heat ,,,,,,,,
If your oven has a stirring antenna in the waveguide, make sure the antenna is rotating. An easy way to check for this is to put in a glass pie pan with just enough water in it to cover the bottom. If you see one or two hot spots where the water quickly boils, the antenna is not turning.
If you have a high voltage probe, measure the voltage at the magnetron end of the diode. (DO NOT try a spark test!) If you get none, then check the door switch in the transformer circuit and check the magnetron power relay on the controller. If those are good, check the capacitor.
If you get high voltage, and you have already verified that the stirring antenna is working, then the magnetron is bad. A common failure in Sanyo/GE microwave ovens is a weakening of the magnet in the magnetron. If the magnet is not strong enough to hold a standard-length #2 Phillips screwdriver shaft to the bottom of the magnetron, it's faded out. (It's a design flaw - the magnetic material lacks has insufficient remanence, and is placed too close to the transformer so the alternating magnetic field from the transformer gradually erases the magnet.)
Oct 03, 2012 | Microwave Ovens
How to remove magnets from sharp carousel microwave
Sep 05, 2012 | Sharp Microwave Ovens
Microwave will light up an looks like it is working but no noise exhuast is not blowing but does not heat food. exhuastfan does work when button is pushed?
Microwaves have a very simple mechanism but with some interesting parts. The most complex part of the microwave is the Magnet-tron. The magnet-tron is the part that does all the job in conjunction with a high voltage transformer. Both of these units would need to work properly for the elements to heat up in the microwave. Now, put a glas of water in the microwave if it does heat up the water to a minimum then the magnet-tron is faulty. If the water does not heat up then the magnet-tron is faulty or the transformer. These are the commune parts in the microwave that fails. There are other peripherals that could be faulty such as the capacitor, the high voltage diode that is connect with the capacitor. Some times the problem is very simple where just a switch is the one not doing it. For example the switch that close the door is not connecting properly also one of the thermostat is open permanently.
Nov 22, 2017 | GE Wb27x10934 Smart Board For Microwave
My microwave magnets keep cracking
Have you checked out your waveguide and stirrer? Also ensure you have good connections & earths.
Feb 04, 2010 | Kenmore 62622 Microwave Oven
My microwave works but does not heat. what might be wrong with it
When this happened to me I had put a refrigerator magnet on the side of my oven, interfered with the magneto somehow. Removed magnet, fixed oven.
Jan 23, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I ran it empty and it shut down. Did I wreck it?
Hello there:
I really dont think you wrecked it, It has a fuse that sits inside of the casing towards thefront all you will need to do is romove the outer case from the back and replace the fuse and you should be fine ok?
best regards michael
Sep 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker microwave turntable makes a grinding noise.
I fixed the problem with my GE microwave turntable motor without having to replace it.
I removed the motor from the microwave and placed it in a small vise. Using a very small flat head screwdriver I was able to pry up the four tabs holding the casing together. You may need a slightly larger screwdriver after that to bend them back out of the way so you can remove the motor cover plate.
Carefully take out all the plastic gears and note their position for re-assembly. You will find that the primary gear, at the bottom of the rest of the gears is attached to the motor magnet. It has a shaft that acts as a bushing passing through the center motor magnet. On the underside it is attached to a plastic washer. This is where it breaks. The motor magnet spins free of the gear/bushing/washer assembly. I used JB Weld epoxy to glue this assembly back together and it works like brand new. Note: On mine there were four indentations on each side of the motor magnet which corresponded to little ‘bumps’ on the underside of the gear on top and washer on the bottom.
Place all the plastic gears back into the motor in the correct order, slide on the motor cover plate and use a small cold chisel with a round end and tap hammer to bend the tabs back into place.
If this worked for you please let me know – [email protected]
Jul 09, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
What can I use a magnetron to do?
Keep it away from credit cards and pacemakers!
The magnets are really strong and they're handy to magnetize your screwdrivers, etc.
May 17, 2009 | Microwave Ovens
Sharp R-1610 Microwave Oven Logo
50 people viewed this question
Top Sharp Microwave Ovens Experts
Michael Thomas
Michael Thomas
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
