AKAI X-1810D LOW HUM WHEN RECORDING REELS
I have an Akai X-1810D. When you record a reel to reel tape, there is a low background "hum" with the recording. When you play back tapes recorded on a different deck, this hum is not present, and vice-versa. I've cleaned, demagnetized, e.t.c. I'm thinking that this may have something to do with the bias head or main head. Any helpful tips will be greatly appreciated.
  • Audio Player... Master
  • 1,267 Answers
I am not an expert in the repair of Akai units- most of the time I refuse them, however just to put you on the right path, the hum is coming from a power supply issue in the record audio section or may be in the bias section. You may need to put new Electrolytic caps in the power supply to resolve this. You can also scope the supplies on this deck to find the cause. I commonly work on Teac, Pioneer, Otari, Studer, Sony and better made decks. Some brands are real trouble and are more costly to repair due to poor construction.
I have been doing repairs for 40 years so far.
Posted on Sep 07, 2012
6ya staff
SOURCE:
robotek
Graeme Ross
  • 1512 Answers
SOURCE: Repairing or replacing old tape decks
Hi m522posner
There is a surprising interest in "vintage" hifi products these days. Your tape machines probably needs new belts. Check this site out. You can get spares for your tape machine here. Belt kits are $17. He does repairs also, but the transport to and from may be an issue for you. I suggest emailing Bob, he may be able to refer you to someone in CA > I could do the repairs,but I am in Australia. :)
Vintage Electronics
P.O. Box 941
1241 Conestoga Creek Rd
Florissant, Co 80816
Email: [email protected]
You could have a go at freshening up the belts yourself:)
regards
robotek
Posted on Jul 12, 2008
Anonymous
SOURCE: play back on Sanyo mr-929 reel-to-reel tape recorder is backwards
I also have an MR-929. The information that you need is in the 'Stereophonic 4 track stereo''. As stereo is only two tracks, there is another 2 tracks in addition to the one you are listening to. Wind the entire reel to the empty spool, and then play that. As you have to physically turn the reel over to do so, you should then hear the other tracks (or track, if recorded in mono).
I use my 929 to play my parents recording of my family from the late 60s, which were recorded on a valve (tube) Ferguson machine, which had a green "magic eye" level indicator, which as a child I found fascinating!
Howie
Posted on Apr 15, 2009
Grubhead
Grubhead
  • 5699 Answers
SOURCE: My AKAI GX 636 records but can't hear anything on playback
Trace the wires from the head to the amp section. Put your finger on where they join (during playback) and see if you can get a buzz. If you can't on either channel, look for something that might be common to both channels. Either a switch, or a pre-amp IC, as being the cause of the fault.
Posted on Aug 06, 2009
Fred Yearian
  • 5603 Answers
SOURCE: Hi my Dad has an Akai 1710 reel to reel tape
Most of the old tape units had rubber "pucks" and belts thaat drive the reels..
The pucks tend to dry out and deteriorate. You MIGHT be able to restore them a bit with the spray used to restore typewriter plattens.
Posted on Nov 15, 2009
Gary Thomas
SOURCE: Hum from vintage Akai DV-4000 open reel tape deck
I have an Akai 4000ds Mkii which had quiet but noticeable hum. I managed to fix it entirely but I had to remount the transformer in a different position and orientation, presumably to 'balance' the magnetic induction it caused in the chassis. I further reduced the hum by adding some steel sheet to the chassis. All this has to be done by trial and error using scrap steel so you need to be exceptionally careful about where the various mains tags are located. You may not be prepared to move so far away from the original design but I suspect your hum is caused by mains induction from the transformer shooting around the chassis. If these currents pass through the chassis anywhere near the playback heads, you are likely to get significant hum.
Posted on Mar 05, 2010
How do play both sides if what looks like a reel to reel tape that has a side 1 and side 2 ? My Akai 1722II does not have auto reverse . Thanks
You take the spools off and put the right spool on the left and the left on the right.
The link also explains, but i started on reel to reel in the late 60s. :>)
how do play both sides if what looks like reel to reel tape Google Search
Good video here
Reel to Reel Basics
Apr 25, 2017 | Akai Audio Players & Recorders
AKAI REEL TO REAL MODEL 1700 OPERATOR'S MANUAL
Here you are Andrew. That is a blast from the past!!
Service Manual and Owner's Manual!
Akai 1700 Manual Stereo Tape Recorder HiFi Engine
Jan 23, 2016 | Computers & Internet
Low volume recording on reel to reel tape deck
Problem could be in either the record or playback circuits of unit. Try playing back a tape in another machine to see what the volume is like. If also low then the issue is with the record amp circuits.
Fixing will not be cost effective, however.
Aug 21, 2017 | Audio Players & Recorders
How to get rid of hum in output of my Akai 4000ds Mark II reel to reel tape recorder
I can't see this question answered anywhere. There is information for fixing hums on bother the Mk I and Mk II models of the Akai 4000DS here:
http://electronicaid.webs.com/
Oct 25, 2011 | Quantegy 456 Reel-To-Reel Recording Tape
My AKAI GX 636 records but can't hear anything on playback (had recorded tape play on another reel to reel) plus the VU needles don't move when you try to play a recorded or pre-recorded tape
Jul 18, 2009 | Audio Players & Recorders
Play back on Sanyo mr-929 reel-to-reel tape recorder is backwards
Howie
Mar 31, 2009 | Audio Players & Recorders
Akai reel to reel GX230D
Try demagnetizing the heads with a head demag device. This is not the same as a bulk tape eraser or a tape demag device.
Oct 17, 2007 | Audio Players & Recorders
256 people viewed this question
Ekse
 Grubhead
Grubhead
