This is a new used stove that I just received from my landlord and does not have the manual..
It should come programmed with ?F. Have you tried to cook anything in the unit to measure the temperature? That would be another way to easily tell. Set it for the highest you can get it and bake something you normally would be at a lower temp for lower amount of time and go from there.
SOURCE: f2 f3 starts beeping when using stove or oven
F2
Oven temperature too hot
Check and replace oven temperature sensor (RTD).
F3
Open oven temperature sensor (RTD)
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
So i suppose its a sensor replacement is necessary.These are the fault code explanations by frigidaire.good luck with the machine.Please do post results and comments.
SOURCE: Stove flashed F11 and then locked the oven door
HI, this is control failure. the logic chip set is damaged. this is causing these erratic commands and the unauthorized locking of the oven door. you will need ot replace the control in this case.(EOC/clock)
SOURCE: F1 when bake on oven is 350 degrees.
You also have a defective electronic control. Replace the clock.
SOURCE: Stove Top on Oven works fine. The Oven has stopped working
there is more than likely a problem with the control board.but you can check the continuity of the bake element.this may also be bad
SOURCE: Oven temperature fluctuates.Oven heats to
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
No need to help...I thought question was clear but I figured problem out myself by downloading emanual...thanks
