Refrigerators Logo
Froilan Santiago-Arevalo Posted on Sep 05, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tablilla Interior nevera Kenmore Modelo 106-5814-3801
I need a shelf for my refrigerator model 106-5814-3801. Is the second shelf if you look from up to down the second one.
Jason Kennidy
Level 3:
  • Kenmore Master 1,344 Answers
  • Posted on Sep 06, 2012
Jason Kennidy
Kenmore Master
Level 3:
Answers
1344
Questions
0
Helped
370180
Points
4021
Apdepot.com or partselect.com are two good replaces to get parts. Repair clinic is also a good place but a little bit more pricey.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
5 Related Answers
applianceboy
Todd Marr
  • 77 Answers
  • Posted on Sep 26, 2007
SOURCE: Kenmore refrig not making ice and top shelf area in refrig not cold
if you are having tempurature issues make sure the fan in the freezer is operating. it should be on when the compresor is running. this may explain both warm fridge and no ice.
bobicehouse
Robert Moller
  • 1524 Answers
  • Posted on Apr 23, 2009
SOURCE: need shelf
Sears Parts Direct
Part for KENMORE, Model # 25336608896 Shelf, sliding, wiring
Part # 218272502 Category:Refrigerators and Freezers $34.41 In stock
Anonymous
  • 6 Answers
  • Posted on Jun 29, 2009
SOURCE: I have a kenmore refrigerator model 36369262991.
I had a similar problem on a Whirlpool Fridge. In fact, there is a good possibility that your Kenmore is made my Whirlpool. As you probably know, Sears doesn't make appliances, but contracts with well-known appliance makers to manufacture kenmore-branded products.
If your fridge is an auto-defrost model, whenever it auto-defrosts, water from the melted ice collects in a tray behind the freezer, and drains into an evaporation tray at the bottom of the fridge through a drain tube. Over a period of time, the drain tube can become clogged, and instead of draining out of the freezer, the water overflows into the fridge. The clue is that the problem is intermittent -- the dripping stops between defrost cycles.
The fix is to remove the liner panels from the freezer, melt and sponge out any collected ice, clear ice from the drain with hot water, and clear any gunk from the drain tube with compresssed air or a flexible "snake." I used 1/8" pvc tubing as a snake.
It isn't hard to do, but if you are nervous about disassembling parts of your fridge, you will need to get a pro to do it.
Sea Breeze
John Tripp
  • 4656 Answers
  • Posted on Jul 01, 2009
SOURCE: Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Anonymous
  • Posted on Dec 14, 2009
SOURCE: Kenmore refrigerator model 46-66812 ice build up on the bottom shelf of freezer
Had the same problem. I noticed that the fan in the freezer never shut off so I suspected the thermostat. I ordered and installed a new thermostat (about $30 and 15 minutes to install), the fan now cycles correctly and the ice build up is gone.
2answers
Kenmore Coldspot Model 106.71182100 - looking for part replacement for refrigerator, specifically a flat shelf in door next to butter compartment.
fixya doesnt sell or manufacturer products -----online parts 1000s of sites or appliance shop in your area
Tengo una nevera no imfria modelo hoover a class. por favor que solucion?
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
TENGO UNA NEVERA SAMSUNG DIGITAL MODELO SR L629EVSS NO PRENDE NADA LE DESCUBRI UN SENSOR DE TEMPERATURA QUEMADO AL CAMBIARCELO UNICAMENTE ME DEBE DE PRENDER'?
Frigorifico SR-L629EVSS faz frio at? a temperatura por ex: -18 4 depois desliga s? quando desligo da ficha e volto a ligar e a temperatura j? baixou .
Model 106-74269401 mfg date 6/05. Constant pool of water on interior top shelf leaking from freezer above. What is standard repair?
That is most likely the defrost condensate pan inside the freezer has frozen over and closed the drain opening. Once that happens then the water has no where to go but the freezer or the fresh food compartment. Below is a link to different ways of this happening. Just choose the section that resembles your refrigerators problem. The water freezing over does not always need to go to the extreme measure to prevent it. It's possibly something blocking the line between the freezer and the pan under the refrigerator. Let me know what you find, Thanks, Sea Breeze
click on link
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
1helpful
My refridgerator dosent work but my freezer does
El problema puede ser el conducto que transfiere el aire desde el frezzer hasta la nevera debe estar cerrado o congelado.
solucion verifica el adjustador de la ventanilla ubicado en la parte superior de la nevera que no se encuentre cerrado si el mismo se encuentra abierto necesitaras a un tecnico por que debe ser problemas con el sistema de descarche que no este funcionado
1helpful
Need shelf
Sears Parts Direct
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
