Component | Fault Code | Possible Cause |
Camshaft position sensor | 11 |
Sensor not connected.Sensor broken. Wiring faulty. |
Crankshaft position sensor | ||
Intake pressure sensor | ||
Intake pressure sensor | 14 | Excessive pressure difference between two pressure sensors |
Throttle position sensor | 15 |
Coolant temperature sensor | ||
Air temperature sensor | ||
Atmospheric pressure sensor (inside ECU) | 23 | Sensor faulty |
Ignition coil 1, Front cylinder | 33 | Ignition coil faulty or wiring not connected |
Ignition coil 2, Front cylinder | ||
Ignition coils 1 and 2, Front cylinder | ||
Ignition coil 1, Rear cylinder | ||
Ignition coil 2, Rear cylinder | ||
Ignition coils 1 and 2, Rear cylinder | ||
Fall Sensor (tip-over sensor) | 41 |
Positive pressure creates a positive air pressure that helps prevent contaminants from entering although this is not necessary, it gives some growers peace of mind that their fruiting chambers are less susceptible to contamination.
