I think the people who offered it, must have turned it on, used it only once, and had it for a long time before they gave it to me, without using it. Could it be limestone? Could it need descalling?
Feed some water with some pressure from the water reservoir hole. You have an air bubble. I followed all the solution ideas but no one worked for me until I designed my own idea. I attached a hose to the hole, opened the faucet and then put the nesspreso pump on and instantly the water come out. Solved problem
With the coffee maker unplugged and an empty cup in place, I filled the reservoir with filtered water and with a short length of flexible plastic tubing I blew in to the small hole in the bottom of the reservoir. I did this 4 or 5 times sucking some water in to the tube to force it through the system. When I had finished there were a lot of grounds in the cup and the next time I used the coffee maker it worked perfectly.
