Question about Siemens SpeedStream Computers & Internet
I need a vista compatible driver for Speedstream6500
I have a wireless internet connection with USBmodem connected to our main computer Dell Inspiron530s, have connected Speedstream 6500 with ethernet cable & USB cable to the Dell and was hoping to create a wireless network for a laptop and ipad4s. I can't find an appropriate driver for the speedstream6500
Paul Woodward
    Sergeant:
  • 198 Answers
Try installing iobit advanced systemcare free software and run drive booster
Posted on Dec 22, 2017
5 Related Answers
Anonymous
SOURCE: Vista/router/wireless connection
ok, so my problem was fixed by manually adding the ISP's DNS IP address to the setup within the router.
I also have a speedstream modem and 520-GC, but connect through AAPT, ISP shouldn't matter in this instance.
If you can't get the IP of the DNS server by calling optus, plug the ethernet cable back into the modem and one laptop, and find it in the web-based modem config (192.168.1.254).
unplug the ethernet cable from your modem/laptop and back into the router. enter the web-config of the router (usually 192.168.1.1), 'Finish' 'save and restart'.
once restarted, you will likely need to restart all computers. if this still doesn't work, command prompt on each computer and type ipconfig /registerdns.
hopefully this will solve it completely.
Nifty
Posted on Oct 11, 2007
Anonymous
  • 3 Answers
SOURCE: Motorola SB5120 Problem with ethernet cable
My PC is connected to my modem with my USB. Because I had to setup up my router, I needed to go through my Ethernet port. What I discovered was that the port on the modem was damaged - pins were misaligned an ethernet cable was yanked out of the socket. I realigned the pins with a screwdriver and that worked, but it's not an ideal solution.
Posted on Jul 14, 2008
Anonymous
  • 240 Answers
SOURCE: Dell Inspiron 6000 won't connet wireless network after reinstall
check DEVICE MANAGER if the wireless card have the right driver installed. if you found that the wireless card have yellow exclamation point on the right it means, you installed a wrong driver.
check also in BIOS if the wireless card is enable and the switch is turn on.
press Fn+F2 to enable wireless radio/anthena (funtion key with wireless icon in blue color)
some dell laptop have hard switch located right side check this and turn the switch on.
if you want to see the icon n task bar, go to control panel....network connection...right click on wireless adapter...select properties...check Show on taskbar
Posted on Apr 03, 2009
Anonymous
  • 8 Answers
SOURCE: 2wire Wireless router not working w/Comcast cable modem
Its almost impossible to connect a 2wire DSL router with a Cable modem. They dont go hand in hand.
Although you can connect the outgoing ethernet wire from the modem in the last ethernet plug on the back of the router and then have the ethernet connections coming from the router. But not wireless. and if you find a way, contact me at [email protected]
Posted on May 06, 2009
dante777
C. Dante
  • 623 Answers
SOURCE: Ethernet on DELL 4550 with TP-link doesn't work
pinging 127.0.0.1 just tells you that your network card is operational and reacheable by your system.
I have a couple of suggestions - check them out and let me know what you found out.
  • Go to Network Connections / Local Area Connection / General Tab / Properties / Internet Protocol (TCPIP) (from the list)/ Properties. Are all settings set to "Obtain automatacally..."?
  • Is your operating system Windows XP Home or Professional (with Service Pack 2 installed)?
  • Have you installed the AirPort Utility software that came on the CD? (Check Start > All Programs > AirPort)
  • You have to have the software installed in order to setup the router.
  • What is your internet connection: Cable or DSL?
  • Take a look at this document "Designing AirPort Networks" which is also on the CD that came with the device. If you don't have it, here is the download (link). Go to page 25 and follow the instructions for PPPoE (if you have DSL service) or DHCP (if you have cable service).
Let me know how that works for you and if you have any more questions, just come back here and leave a comment - I'm happy to look further into that if this did not work for you.
Posted on May 27, 2009
I have a wireless card on my inspiron b130 computer but I still can not get internet
You need to install the drivers, compatable with the Operating System on your computer, for the wireless card to work.
Aug 30, 2014 | Dell Inspiron™ B130 PC Notebook
My Dell Inspiron 560 suddenly stopped connecting to internet through cable-modem.
Onboard adaptor hardware failure? Or is it missing Drivers?
Wireless adaptor - did you install drivers for adaptor? Did you check that WiFi on the adaptor is switched on?
On a side note: I've found that USB 2.0 Wireless N adaptors are the best for connectivity, as they have their drivers on the adaptor, are fully plug and play (Vista/7/8 and even some models on XP). I recommend Transcend (brand name).
Nov 28, 2011 | Dell Inspiron 560 (Intel Pentium Dual Core...
Describe your 946 All-In-One InkJet Printer Problem I'm running windows 7 on a Gateway laptop and managed to get it to print at one point but then installed some other items to get it to recognize...
This printer is not a wireless rpinter, so I guess you were trying to attach it to a print server of some type.
Try using these Recommended Wireless Router Settings,I use channel 11. I would make a new SSID to make connecting easier.
If your computer came with Windows 7, then follow the procedure below. If you upgraded your computer, the did you install the chipset drivers first. If using a Dell Computer that was upgraded, the desktop/notebook system utility and the chipset drivers need installed first or the rest of the drivers will fail to install. How to Download and Install Drivers in the Correct Order
First run Delete Print Jobs to remove any stuck print job in the queue.
Disconnect the printer.
Download and run the patch(printer cleanup utility) until it prompts you to restart your computer.
Restart your computer. Make sure the printer is removed.
Manual Printer Driver Removal
Download the Vista 32-bit drivers for Windows 7 32-bit or the Vista 64-bit drivers for Windows 7 64-bit. Install the Vista drivers in the Vista
Compatibility mode You'll get a message, the printer is not connected. Connect the printer at this time(powered on).
Links to the patch/drivers can be found at...
Dell 946 Photo All-In-One Printer owners thread (W7)
Virus programs and firewalls will block communications.
If you need more help, please post in the Dell Printers Forum
Rick
Aug 24, 2011 | Dell 946 All-In-One InkJet Printer
I hav dell inspiron 1525 and i installed new windows vista but i couldnt connect to internet because it says "install wireless networking hardware and verify that correct drivers are loadedcan you please...
I presume that Vista has just been installed and connecting wireless. Check if the Wireless switch is on (edge on the right side. IF no change, install the software driver that is on Drivers/Utilities CD that came with your computer. Please comment if the information has been helpful. Thank you and regards.
Jun 29, 2010 | Dell Inspiron 1525 Laptop Jet Black
My main computer is vista, the one with wireless router , but I want to use my xp computer with the dell 1450 wireless usb adapter. it won't work
Dell do not provide support for vista on the 1450 USB adapter - see here http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&cs=19&l=en&s=bsdv&dl=false&docid=20075A1DBD60D650E0401E0A55175C46&doclang=en
I have not tried this - but found on another forum http://www.vistaforums.com/Forum/Topic5380-21-1.aspx olution:
  1. 1) Install the Dell 1450 USB drivers on a PC with XP32 (assuming your target machine is 32-bit)
  2. 2) Copy the "2K" drivers from the install directory ( c:\program files\dell wireless ) to a flash drive.
  3. 3) Copy the "2K" drivers from the flash drive to the Vista machine. After you plug in your 1450 choose to manually select the driver then browse to that folder. You should be up an running in a few seconds.
The extra connection manager software that came with the adapter won't run on Vista but you'll still get a good wireless connection.
Apr 13, 2010 | Dell 1450 (D1450U) Wireless Adapter
I am trying to connect a Dell Inspiron 1545 with Vista basic software and it says not compatible. Any suggestions?
Can you reinstall the wireless card drivers from Dell again? Also, create a new connection and delete the current one that does not connect?
Jul 07, 2009 | Arris SURFboard SBG900 Wireless Router...
Problem with connection of networking and VOIP.
Go to your Run program on the computer that your are having connection problems with. Type cmd.exe in the box. When your DOS page appears, type in ipconfig/ release. Be sure to use a space between the / and the word release. After it releases, type in ipconfig/ renew, using the space as well. Close out of your DOS. Recheck your internet connection. Before you recheck it though, make sure that your computer's wireless password, if you are using any, are the same as your wireless router's password. Hope this helps.
Sep 07, 2008 | Compaq Presario Notebook
Internet Explorer cannot display the web page
Could be a vista compatibility problem.
check Linksys website for updated driver and or connection manager.
check that you still have permission in firewall.
remove the software of the usb wireless adapter,reboot ,then re install.
just a couple of thoughts
good luck
Terry
Mar 26, 2008 | Compaq Presario 5000 PC Desktop
Windows Vista and Dell Wireless 2350
Try updating the driver for your wireless adapter.
Jan 22, 2008 | Dell Wireless 2350 Router
Laptop connection to Internet
In the simplest terms buy a longer ethernet cable or multiple ethernet cables and route them to several preferred areas.
However believing you probably would like to connect wirelessly
If your laptop has a built-in network card and originally came with Vista you may need to configure the network adapter and/or the router appropriately. There are often user guides for the both the adapter and router that will assist.
If your laptop has an built-in wireless adapter and you upgraded to Vista you should check the manufacturers website using support or drivers links to see if they have Vista software/drivers to support your built-in wireless adapter. IF not you may want to consider the purchase of a compatible add-on wireless adapter as noted below. And perform the appropriate configuration(s) as noted above.
Likewise if your laptop does not have a wireless adapter you may wish to consider purchasing an adapter. Care must be taken that the adapter is compatible with your computer, your operating system (Vista) and your wireless router (apparently WBR-1310).
Dec 06, 2007 | D-Link 802.11g Wireless Router WBR-1310...
Computers & Internet Logo
44 people viewed this question
Top Siemens Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Terry
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
