With the help of my Father (Who is a Plumber) We turned down the Temp gage on the water Heater. Set at aboput 127 degrees. But now we dont even get warm water from it.
For electric tank: Push in the reset button located on upper thermostat.
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
For gas tank, then more specific information might be needed for example if unit has power vent, when was the air intake cleaned, is the pilot lit, what brand and model number etc etc..
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
For tankless, or solar, or hybrid electric, gas boiler, or indirect, or RV heater, etc then please include brand, and model that appears on label on side of unit.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: my water is luke warm and then runs cold and then
Its time to replace the heating elements. 90% of the time it's going to be the bottom element, but if you're going to drain it anyway, elements are only $10.00 to $12.00 I would go ahead and replace them both. Replacing the elements is simple just follow these steps.
Step 1: Turn off the power to the water heater.
Step 2: Turn off the cold water valve supplying the water to the heater.
step 3: Drain the water heater there are a few steps to proper draining, connect a hose to the drain port on the lower front of the heater and open the drain valve (remember its gravity drain so downhill all the way) pull up on the pop off handle to relief the pressure in the tank and to let air in so it can start draining also open the hot water valves in your tubs and showers (the more air you can get in the faster it will drain)
Step 4: Undo the 2 wires connected to the heating elements and unscrew the element counter clockwise until it comes out of the tank (they make a socket type tool for removing the elements it's real cheap and can be found at any Home Depot)
Step 5: Take the elements to Home Depot (or any hardware store) and find the exact replacements also get a 1/2" roll or Teflon tape.
Step 6: Teflon tape the threads on the elements (with the threads facing you apply the Teflon tape clockwise) about 4 times around the threads is good.
Step 7: Reinsert the elements into the holes and snug them up tight. (Clockwise) Not supper tight
Step 8: Reconnect the wires to the elements they are 220 volts so there is no neutral either wire to either screw is fine.
step 9: Close the drain valve a disconnect the hose make sure the pop off is closed and turn the water back on leave the tubs and showers on until the tank is filled and air quits coming out of them . Check around the elements for leaks if you see a leak simply snug it up a bit more.
Step 10: Set temp to 125 or whatever you find efficient, replace element covers and turn the power back on and you're all set.
SOURCE: water will not get hot
I had the same problem after only one year after i installed it. i called and gave them all the codes and they stepped me throught some diagnostic stuff i had to do on the remote control display and they figured that the mixing valve was stuck open and that is why it wouldnt get hot. they sent me a pdf file that showed me how to use white vinegar to clean the inside of the manifold and other parts including the valves. after i did this everything worked perfect. there was a lot of **** in there even with the screen filter. now it get real hot at a lower temp setting. hope this helps you out. check to see if your manifold gets real hot and if it is hot and after the mixing valve it is cold then that is your problem
SOURCE: Water temp stays at 160 degrees
Specific type of water heater does not show on web search.
I am guessing you have tank-type electric water heater.
Did you replace both thermostats and test elements?
Element could be cracked, thermostats can stick open, upper thermostat wired incorrectly, wire shorted.
We know that electric power to water heater is good, and circuit breaker is good.
Why is eco is not tripping? Why is TP valve is not leaking?
Copy following links for step-by-step:
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
http://waterheatertimer.org/How-to-test-water-heater-element.html
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
