Water dripping from the pump. Which part do I need to get the fuse along with the pump and can I intalll myself?
SOURCE: Fisher and Paykel washer dripping water into tub.
Dear FixYa Customer,
First and Always go to the Manufacturer for Parts Compatibility and/or Service!
For a GREAT APPLIANCE PARTS WEB SITE click on the highlighted http:// link that follows...
Same-Day Shipping, Return Any Part
Save When You Do Repairs Yourself! @
http://www.partselect.com/Entry.aspx?
jackiaria
SOURCE: how do you replace the pump on a fisher paykel eco
No the pump is removed from the bottom, tip the machine over 45 degrees and look underneath.
SOURCE: Water leaking from under washing maching
The ribbed drainage tube on mine was leaking from a small hole at the bottom of the curved "u" - due to flex fatigue tiny crack. My solution - a short (1 inch) section of copper water pipe for a splice, secured with black electical tape and a hose clamp. This fixed the leak, but when I stood it back up, it wouldn't run right. This was due to the out of balance microswitch mentioned above, which was corroded. I bypassed it, and it works like new.
dt
SOURCE: fisher paykel gwl15 won't pump out water
My F & P Model GWL15 did the same thing. I purchased a new pump but that was not the problem. Tip the machine back and look under. There is a valve diverter that I removed and checked. There was a dime and lots of lint stuck in the valve so it wouldn't move back and forth anymore. I downloaded a parts manual, page 10 and item # 23 is the valve diverter. Once I unclogged it and put it back together, it worked great. I noticed it works better than it has for a long time. I'm a 60 yr old woman so anyone can do this. Good luck.
