I want to remove the hard drive from the Toshiba Estudio 450 scanner module prior to recycling/donating the copier. My husband wants that albatross out of his shop! Please help. Thanks, Byrdie
Pull off the back cover, then the metal cover that has the two wire fan plug going in to it. The hard drive is under there.
TOSHIBA PARTS AND SUPPLIES
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
SOURCE: toshiba estudio 161 copier
1. Entering the simulation mode
Perform the following procedure to enter the simulation mode.
"C" key AUTO/TEXT/PHOTO key
Main code Start key Sub code Start key
(Note:Perform the first four key strokes quickly allowing no more than one
second between key strokes.)
if the machine dies enter the code 14, then press start, the machine wil reboot and the problem wil be solved, if not , contact your nearest service centre
SOURCE: Turn Off Power Save Toshiba eStudio 150
Don't know if this applies to Toshiba but Xerox machines have the same annoying problem, which is NOT fixable.Xerox machines are used in the EEC who insist that power save is not resettable only able to be set to 120mins max Gotta save the power y'know!
SOURCE: reset fax data in toshiba estudio 350/450
how do I find my IP address for my Toshiba e-studio350
restart machine ,then press the 0 & 8 keys,enter 263, then press Start. You should see admin password on the screen.
SOURCE: COPIERS - E-STUDIO 650 Copier: We have a Toshiba estudio 550 copier and are copyi...
Copier is copying pages with dark areas down at the bottom.
described simple words
I found it. Just kept removing panels til I located it.
