Toshiba Satellite P755-s5120 Core I7 Pc Laptop Logo
Anonymous Posted on Sep 04, 2012
If I want to add more memory beyond the 8gb max from the MFR, will it work?
I want to increase the speed of document rendering since the memory is shared between the CPU and virtual graphics card for the Toshiba Satellite P755-s5120. It is possible to swap the (2) 4gb memory sticks for (2) 8gb memory sticks and get the results or will it not work? I'm running Windows 7 64-bit. Wondering if anyone has tried this yet????
Anonymous
Level 3:
  • Toshiba Master 32,281 Answers
  • Posted on Sep 05, 2012
Anonymous
Toshiba Master
Level 3:
Answers
32281
Questions
Helped
7905726
Points
102259
You cannot add more RAM that the recommended max. specified by the manufacture.
If you could install more than it 8Gb, either the laptop won't work OR it cannot access more than 8Gb of RAM.
5 Related Answers
Anonymous
  • 8 Answers
  • Posted on Nov 22, 2007
SOURCE: can I add another 512MB of memory to my A105 satellite toshiba
i dont know as much about laptops but you should be able to get the 512MB. to replace it look on the bottom on the laptop there should be somewhere down there that you can open up the to put it in.
Anonymous
  • 13 Answers
  • Posted on Mar 30, 2009
SOURCE: Not enough memory
The maximum memory for the Toshiba Satellite M35X-S311 is 2GB using 2ea - 1GB DDR SO DIMM, you should be able to use different sizes of memory in this computer, but this is not always the case with all computers. they only come in 256, 512, and 1GB and came with 1 512MB from Toshiba. The odd amounts of RAM available are due to BIOS files loading.
Anonymous
  • 19 Answers
  • Posted on Sep 09, 2009
SOURCE: Need To Upgrade Or Somehow Add A New Graphics Card
There is a way, yes, but it requires a few tools and no fear as you rip into the laptop case. I could explain this in detail but I'll leave you with this tutorial on the 'HOW-TO' side of things to browse at your leasure:
http://www.pcworld.com/article/148909/upgrading_your_laptops_graphics_card.html
However, upgrading the RAM will improve speed (if that's what you're really going for). Otherwise, adding a more powerful card may not increase your screen resolution but can add more kick to your gaming experience.
If you're just looking for a little more speed with higher resolution, I'd upgrade the RAM a bit and purchase an external flat screen 1080P 22" monitor that'll plug right into the back of the laptop. It will save you the frustration of possibly damaging the internals of your pc and the disappointment when you realize that the increase in performance isn't worth the risks/effort involved in switching out the cards.
Anonymous
  • 32281 Answers
  • Posted on Oct 10, 2009
SOURCE: toshiba satellite memory stick problem
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Anonymous
  • 129 Answers
  • Posted on Sep 04, 2011
SOURCE: Hello, I have a Toshiba
your computer can be upgrade up to 1.5 gigabytes of ram with a PC2700 memory specifcation compliance.
1helpful
Can i increase DDR memory in my HP H61
Search your model here to find out max capacity and memory type.
http://www.crucial.com/hp/
2answers
I want to add 4GB of DDR3 memory, what further info to I need to know about the memory?
Newegg has a great site to find the correct and most compatible memory for you Here.
To maximize your ram speed, use the same speed and types of ram
For example, if you have a 1GB right now, add three more 1GB than putting in a 2GB and 1GB.
If you have a 4GB ram stick right now, add another 4GB and not 2x2GB. Also make sure the MHz on the ram is the same, (1333, 1600, 2000)
Enjoy upgrading your computer!
6helpful
5answers
I increased memory from 512 to 768 on Dell desktop with 2.4 celeron but did'nt seem to increase speed.what is the problem? Ray.
That minimal amount of increase is not going to be a very noticeable increase also the processor or a faster RPM hard drive is more for the speed. you can go to the system properties in control panel and then the advanced tab and then the settings tab on performance then to the Advanced Tab then to change tab in virtual memory then to custom size make the initial setting 1.5 times the amount of memory installed in your case 768 x 1.5 = 1152
on the max 3 x the amount of memory again, in you case 768
768 x 3 = 2304
1helpful
2answers
HP Pavilion dv7 ram upgrade, came with 4gb ram, supposedly is able to upgrade to 8gb, is this possible?
Yes. The specifications say the MAX memory is 8GB
Memory 4096MB Memory Max 8192MB
You should go to Crucial.com and run their online tool for ram upgrades. It will tell you exactly how much and what type of memory to add.
Thanks for using FixYa.
Overclock fan speed question
The amount that you can overclock you're video card differes for each individual card. The limiting factors are temperatures and stability. If games start crashing, etc you should back off the overclocking. Also keep in mind the temperature of the card. Increasing fan speeds will lower the temperatures of the card. Increasing the fan speed (as long as you don't go beyond 100%) will not damage the card... It will be louder though. For the 9800gt, the maximum temperature before damage is 105 degrees C. Try to keep the temperatures at 80 or below optimally. Increasing the fan speed is the best way to accomplish this.
Is there a way to upgrade the 700wx to use 8gb memory card?
if its maximum capacity of the Palm Treo 700w... is 700wx you cannot use any memory card beyond that because it hang the programms,bt if its maximum capacity is beyond that then you can add 8gb memory card.
2helpful
2answers
1helpful
There is risked that adds it? Becose i want to add 2 more GB of ram too, now i have 1 GB...
These are the memory mods for your motherboard. It looks like you would max out at 8GB (4x2GB). You would need to verify the clock speed and such on the 1GB you already have (take the part number off of the chip and punch it into Google for a reference). Cross populating memory of different speeds isn't the greatest.
Note: I am not affiliated with the linked vendor, it's simply for illustrative purposes only.
Increasing memory beyond 512meg
did you get the right memories???
DDR266, SDRAM???
basically the memories is PC2100, 266Mhz
ya! 2Gb max out.
check your BIOS
Pc died
Hello, I have had similar problems with that same motherboard in the past and have found that resetting the cmos (see users manual) or just taking the battery of the motherboard for a few minutes can solve this. CAUTION please remove the power lead on your tower before touching any components inside, and earth yourself first by touching metal.. as static discharge kills pc components..
Hope this helps.....
Tony.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
