SOURCE: Sony CX-12 Camcorder gives message when memory stick inserted
Hi!
This is a feature and not a defect of the CX-12 that reminds the user that the memory stick inserted might not be able to record the data from the camera effectively. HD video requires a memory stick with a relatively fast data read/write speed, and the CX-12 recommends not using any other stick that is not Mark 2.
Fortunately, though, as you have found out, it does not affect the camera's ability to record in non-Mark 2 sticks.
Hope this helps!
SOURCE: What memory stick works in the DCR-TRV340 Sony Handycam?
Mine says msa-4a. the duo sticks won't work. You will the larger older memory sticks
SOURCE: Memory Stick Pro Duo with adapter not compatible with the camera
I am so sorry my friend, you have same problem as we all have, no memory bigger that 1 gb will work in cameras older than 3 years, I think yours is yes? the camera simply does not see those, sad I know, but that is how it is, I know because I have 3, yes 3 adaptors and 3 big mem bits here, and my money is lost.
David
Suffolk
Testimonial: "Thanks very much! Bad news but very helpful :-)"
SOURCE: I can't see any image
Try playing one of the tapes on another Sony DV/DVCAM device and make sure the tape is OK. Also, try running a cleaning tape through the camera for 8-14 seconds (no longer!) on playback. If this does not remedy the problem, then your camera needs repair.
SOURCE: I have a sony dcr-trv530
Hello
Try this. Remove the memory stick your camera. If
there is a LOCK switch on the back of the Memory Stick Duo, please be
sure to set it to the unlocked position before attempting to delete or
write data to the stick. If the switch is left in the locked position
when attempting to delete or write, the data on the memory stick may be
damaged.
Please reply here if you still need assistance.
In DSCT1 Camera, the C:13:01 error message indicates a Self diagnostic message. Each of these codes indicates the symptoms and resolutions of the Camera. In C:13:01, the issue is with the Memory Stick being used in the Camera.
The Symptoms are:
Memory Stick Pro Duo 4GB is not compatible with the DSCF707 Camera. Maximum capacity supported by the Camera is up to 128MB. Please try using a MS with 128 MB and check if it works. A dedicated adapter (MSAC-M2) must be attached to use Memory Stick Duo or MagicGate Memory Stick Duo media.
Thanks.
KenSolutions
FixYa
