My system problems are critical and really need the key, i downloaded a software named pc utility kit and it wants a code
SOURCE: XP DRIVERS DOWNLOAD- NEED URGENTLY
Hi... it will be to ur advantage if you post the pc model no because there are a lot of compaq presarios out there.Well you already know the HP support site for download of drivers but you might be unable to detect which are the appropriate ones for you. If this is the case, Plz log on to www.driverguide.com or www.officiladrivers.com where your system will be scanned for appropriate drivers and will be installed automatically for free. Post any further doubts.
SOURCE: Need Driver and Motherboard Details
Due to large number of model numbers Sahara laptops can have... Start from this link.
http://www.saharaglobal.com/support/list/step_2.jspc?lang=en&loc=INDIA&cboCatName=NOTEBOOK
You should be able to find the exact model number on the label at bottom of the laptop.
Cheers!
SOURCE: I want to riformate my pc but i haven't the disk
You do not need to format the hard drive, you can restore the computer to the factory setting
factory settings means your computer would go to a state as it was on very first day of purchase.
If you want to restore the computer to factory settings and you have window vista, start tapping F11 at the startup of your computer and your computer would be restored to factory settings.
If you have window XP use F10 at the startup.
However, if you want to format the hard drive, you can format it and you have already downloaded all of the drivers.After formatting, first install network drivers and then remaining others. Also, I would suggest you not to install the drivers for BIOS.
I need a order ID
