When i re boot my computer, it shows--------- press f11 for BBS POPUP Initializing USB Controller...don 1016 MB OK USB Device(s): 1 keyboard Auto-Detecting Sec Matster..IDE Hard Disk Auto-Detecting Sec Slave....ATAPI CD ROOM Sec Master: ST3320620A 3.AAE Ultra DMA Mode-2,S,M,A,R,T. Capable and Status OK
SOURCE: Asus P5RD-2-UM acpi bios revision
no keyboard detected. fatal error... system halted = your keyboard is dead, replace it. If you get the same message after a new keyboard then the PS2 connector is dead, you will have to use an USB keyboard.
SOURCE: ai got an old computer and it it work but it show me an error with American Megatrends
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA the leads from your ((motherboard to your hard drive)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty even something as small as an electrical extension or a faulty fan lead can cause this problem a computer needs all of the data and electrical current to travel through every working device and to have an end to be able work properly motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working make sure the CPU central processing unit has thermal paste and dust free and is securely seated make sure your computer ram modules are securely seated with no dust in sockets also Cmos battery has charge with no dust in the socket some motherboards cmos batteries are soldered in
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they could be faulty ?
hope this helps you
hope this helps you
