Printronix P7005 Matrix Printer Logo
A
Anonymous Posted on May 22, 2017
After installing new chip based cartridge on printronix , the printer displays unknown cartridge install new cartridge Details the new cartridge is original with a chip embedded below the cartridge. but still the printer is not able to detect the new original cartridge. showing the "unknown cartridge install new cartridge" but the old cartridge came with the printer is working and showing 17% ribbon life.therefore please advice how rest the new original chip based cartridge printronix p-7005 printer.
5 Related Answers
Anonymous
  • Posted on Mar 03, 2008
SOURCE: Printronix P7210 Ribbon problem
Call 800-854-3181 to talk to a LIVE tech support which is located in the US.
Anonymous
  • Posted on Jul 23, 2008
SOURCE: GAP NOT DETECTED ERROR ON PRINTRONIX T5000 PSN
My label printer quit printing the barcodes on the labels.
I am just getting a series of lines.
I have tried unplugging the machine and still have the same result.
I have tried to calibrate but that is not working either.
Thanks in advance for any suggestions.
Anonymous
  • 495 Answers
  • Posted on Dec 31, 2008
SOURCE: printronix 500 printer is not working
Go to site below to download your driver
http://drivers.softpedia.com/get/PRINTER/OTHERS/index5.shtml
jo_chinmay
Chinmay Joshi
  • 148 Answers
  • Posted on Jan 08, 2009
SOURCE: i have a problem with ribbon gear of printronix p500 line printer
in india call 09924444848 as i know he supply it otherwose printronix service center or CMS computers , or wipro help u...
Anonymous
  • 31 Answers
  • Posted on May 29, 2009
SOURCE: Re: Printing Garbage
I believe you have this setting incorrect: the MFRTYPMDL should be *IBM6400EP. That is because you want the AS400 to send out plain old ASCII to our printer. It is an ASCII printer and not a HP. The codes are different.
Printer given barcode missing install new ribbon
There are two styles of P7000 a spool ribbon style and a cartridge ribbon style. You are getting a barcode error then your printer is looking for a ribbon spool not a ribbon cartridge.
Cartridge Ribbon:
PRINTRONIX 255048 402 P7000 EXT LIFE CARTRIDGE RIBBON New
Spool Ribbon:
PRINTRONIX 179499 001 ULTRA CAPACITY RIBBON 6 PACK New
2answers
Printer officejet pro 8600 cartrige 951 is full but printer thinks its empty. how to reset printer
use only new cartidge. Its the best thing you can do if you want your printer work fine with no trouble.
Crtg missing instal new ribbon printronix p7005
This error message normally happen due to following reasons..
1. Didn't remove protective tape on cartridge.
2. Didn't properly seat cartridge.
3. Contacts on carriage need to be cleaned.
4.If you inserted and removed Cartridge many times..
Try to do it: You can wipe the copper contact plate on the cartridge over with a slightly damp piece of kitchen towel using distilled water. While doing this you need to turn off your comp and printer. Let the contact plate dry for a minute or two before putting back on.
After inserting the cartridge, run the print head cleaning program 3 to 4 times for best results as this will clean the heads and push the ink through.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Magenta cartridge leaked for some unknown reason. when we replaced it, it says the new cartridge is empty. Please help.
Hi
My friend the cartridge which leaked earlier has spilled ink in side on the contacts of the printer where the smart chip comes in contact. Try to clean well with a tissue paper and try to insert slowly into the printer and this will solve the problem.
If not then carefully remove the smart chip from the old one and replace it with the new and install back in the printer.
Take care.
1helpful
Replaced black ink cartridge and printer keeps asking to replace
The message that persists in saying to "replace black cartridge" could be due to a defective cartridge chip. The chip maintains counts and tells the printer when a new cartridge is installed. If you cartridge is remanufactured, they may have neglected to install a new chip.
Regarding the new fuser not working, I'll have to get back to you on that.
Installed #8 M(magenta ink cartridge) New ink tank.
The problem can be one of the following:
  1. You have a faulty cartridge chip (return to purchaser and request a replacement)
  2. The chip is soiled (ink or similar is causing the connection to fail) so try cleaning the chip
  3. The chip is not properly mounted on the cartridge (maybe skewed slightly or similar). If so try straightening out carefully and then re-inserting.
Canon have been known to send out cartridges with bad chips so you should contact them if you bought a proper one and they'll sort you out.
2answers
Replaced HP LaserJet 2840 catridges and now [?][?][?][?] ! error
The OEM cartridges have a chip on them. If the aftermarket supplies do not have the right chip, missing a chip, etc., the machine will not recognize. Placing the old cartridge back in without any toner can give off the same message.
Try rebooting the printer without a cartridge in. Then install the cartridge, either one, and see if that helps. If not, wait for the OEM to arrive.
Epsom stylus CX4700 won't print - new ink cartridges installed
They cut costs on Epson compatible cartridges by using low quality ink and chips or not resetting the chips at all. Sounds like you got cartridges that the chips were not reset on so your printer thinks all the cartridges are empty. I own a Cartridge World ink refilling store and I would never recommend purchasing compatible Epson cartridges from anyone. I would buy refills of Epson brand cartridges and make sure the seller reset the chips.
9helpful
2answers
Memory error
Just do 2 steps:
1. Press Stop.
2. If the display highlight "Resume". Press the OK (Check Button).
The display will tell you that a Non-HP Cartridge is installed and Economode is Disabled.
At least, you can now print. The display will show back again to "Ready".
Top Printronix Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
