Question about Casio Fx-992s Scientific Calculator
How to compute mean and standard deviation with fx 992s casio?
5 Related Answers
Anonymous
SOURCE: how to do standard deviation on a casio fx-300 MS
http://www.geocities.com/calculatorhelp/casiofx300ms.htm
Posted on May 14, 2009
k24674
  • 8091 Answers
SOURCE: Standard Deviation
In the main menu select [STAT] icon to enter Stat mode and display the statistical data lists. Use the satistical data lists to input data and perform statistical calculations. Use the arrows to move the highlighting around the lists.
Exemple: Enter the following values in List 1
1st line enter 90 [EXE]
2nd line 85 [EXE]
3 79 [EXE]
4 75 [EXE]
5 70 [EXE]
6 68 [EXE]
7 56 [EXE]
When finished you press [F2:Calc], then [F1:1Var] and the statistical results appear on screen.
Title of screen : 1-Variable
x bar =74.7142857
Capital Sigma x= 523
Capita Sigma X squared = 39851
x lower case sigma n = 10.5249945
x lower case sigma n-1= 11.3682934
n = 7
Scroll down with Down arrow to access other data
minX =56
Q1=68
Med =75
Q3=85
Xbar -x lower case sigma n =64.1892911
x bar + x lower case sigma n = 85.2392802
maxX=90
Mod=90
All you have to do now, is to look at the theory you learned and interpret what these values mean.
Hope it helps.
Posted on Sep 19, 2009
Anonymous
SOURCE: standard deviation
standard deviation
calculate mean of a data set:
1. Turn calc. on or press MODE SeTUP
2.Press 3 for STAT
3. Press 1 for VAR
4.Enter values for X column
5. WHen done entering press SHIFT 1
6.Press 5
7.Press 2 to calculate the mean
8.Press =
k24674
  • 8091 Answers
SOURCE: FX-115ES Scientific Calculator: how to do standard deviation...
I assume you know the theory. I will show you the key strokes for 1-Var statistics and 2-Var statistics
Press [MODE][3:STAT] [1:1-VAR]. You are ready to enter values in the X column.
Enter a number and press [=]. Cursor jumps to second number to enter.
Keep entering numbers and pressing [=] till all numbers are in. Press the [=] key after the last one.
Press [AC] key to clear the screen.
Press [SHIFT] [STAT] (above digit 1.) then [5:Var]. Screen displays the statistical variables 1:n ;2: x bar; 3: x sigma n; 4:x sigma n-1.
Press the number corresponding to Referable you want, ex 1:n . The variable appears on screen. Press [=] and it will be displayed.
To display another variable press [SHIFT][STAT][5:Var][ 1,2, 3, or 4] .
- To access the sum of squares sigma x^2 and the sum of data sigma x press[SHIFT][STAT][4:SUM] then [1: for sigma x^2] or [2: for sigma x]. Press [SHIFT][STAT][6:MinMax] to access minX and maxX.
To perform 2 variable statistics you press [MODE][3:STAT] and any of the other regression options (except 1:1-Var). A two column template opens where you enter the X and Y values. When finished entering data, press [SHIFT][STAT][5:Var]. to access the different statistics. As I assumed above, you should be able to recognize what each variable means.
Posted on May 21, 2010
Anonymous
SOURCE: How to do standard deviation calculations?
Parameter Value
Mean 500
Standard deviation 100
Left cutoff 400
Right cutoff 600
Results
Probability to the left of the tail 15.87%
Probability in the center 68.26%
Probability to the right of the tail 15.87%
Posted on Jun 21, 2010
How do i calculate Rec on fx-992s casio calculator?
Rec? Conversion from polar to rectangular coordinates ? You need and a radius (length) and an angle (Rec (r, theta)). Make sure the angle unit is the one you want: degrees or radians.
Dec 27, 2016 | Casio Fx-992s Scientific Calculator
Standard deviation
Follow the instructions beginning on page 26 of the FX-570MS manual: http://support.casio.com/pdf/004/fx115MS_991MS_E.pdf
Jun 15, 2013 | Casio Fx-570ms 2-line Display Scientific...
How to calculate the standard deviation? casio power graphic fx-7400G Plus
Here are the capabilities of the Casio calculators.
The screen captures may not look like ones taken from the FX-7400G
plus display but the instructions are accurate.
In stat enter the values in List1 and the frequencies in List2 (if doing paired variable statistics)
Press the key corresponding to the CALC tab
Press the 1-var tab and you get the results as seen on the screen with title 1-variable.
Other screens show some two-variable stats or regressions.
Use you knowledge of sample standard deviations and
population standard deviation to select which is relevant to your case.
They are given by xsigma-n and xSigma n-1
Aug 15, 2011 | Casio FX-7400G Plus Calculator
How to use that standard deviation on the Casio fx-260solar calculator
  1. Calculator must be in SD mode (standard deviation mode) :Press [MODE] [.]
  2. However, if [FIX] or [SCI] appears on display you must press [MODE][9] first.
  3. Data input always starts with [SHIFT][SAC], to clear the registers of old data.
  4. Type a number and press the [DATA] key, it is the [M+] key at the bottom right of keypad.
After you finish entering the data
Press [SHIFT] [9] (sigma n-1) to get sample standard deviation
Press [SHIFT][8] (sigma n] for the population standard deviation
Press [SHIFT] [7] (xbar) for the mean
Press [SHIFT] [6] (n) for the number of data entries
Press [SHIFT] [5] (capital sigma x) for the sum of values
Press [SHIFT] [4] (capital sigma x to y) for the sum of squares of the values
For additional information you might consider taking a look at the calculator manual
Apr 27, 2010 | Casio FX-260 Calculator
How to do standard deviation on a casio fx-300 MS
Mar 11, 2009 | Casio FX-300MS Calculator
How to compute standard deviation given a set of numbers?
Jan 15, 2009 | Casio FX-260 Calculator
Standard deviation
standard deviation
2.Press 3 for STAT
3. Press 1 for VAR
6.Press 5
8.Press =
Oct 05, 2008 | Casio FX-115ES Scientific Calculator
Standard Deviations
This calc will do standard deviations. In the manual it is on page 2 and also on page 40.
Sep 07, 2006 | Casio FX-7400G Plus Calculator
Casio Fx-992s Scientific Calculator Logo
503 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Marvin
Marvin
Carlo Barzo
Carlo Barzo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
