Firmware upgrade I've contacted my ISP about a firmware update since everything I've read says it's not owner upgradeable. My ISP refuses to upgrade or do anything but tell me I need to lease one of their modems. Is there a third party firmware upgrade or a way to get it from Motorola? I need version 3.3.1.0-GA-09-058-NOSH any suggestions?
The ISP is correct in telling you not owner upgradeable. Only because the upgrade is their property. The firmware is coded for their cable lines to distribute the power levels through the cable. If you're having intermittent disconnects, you should call them and ask for a LEVEL3 tech to come to check the cable connections from the "TAP" (which is where the cable comes to home), it's possibly needed to rewire the cable and splitters in your home
1. RESET
While "NO DISC" message appears on the display of main unit, hold the main unit's STOP button for longer than 5 seconds. "INITIALIZE" appears on the display and all settings will return to the default values.
Using the RESET function will erase all stored settings.
2. Firmware update Upgrade File ver 1.3, All OS (ENGLISH) 18 Sep, 2007 Upgrade guide ver -, All OS (ENGLISH) 21 May, 2007 HT Q20
Go to itunes. There, wait for itunes to recognize your iphone. It will then ask you if you want to upgrade. Click yes. If it doesn't ask you if you want to upgrade, try to find the manual button that says upgrade. Don't try to upgrade without using itunes
You can download any available ODD (Optical Disc Drive) updates from http://us.lgservice.com. Click Product Support, click Optical, choose your model number from the list, and click go. Click the Drivers & Software tab. Download the latest version posted (highest number).The firmware for all recent drives works with Windows. Before running the update, make sure the drive is empty. Close as many programs running the background as you can. Run the downloaded executable file to start the update. Some will automatically start updating the dive and some will require you to push "Upgrade" or "Start". If the firmware doesn't see the drive it was designed for, it will not install. WARNING: Never update the firmware if the problem you're having is the drive isn't seen by windows, won't write with the included software, or other interface related problems. Unless the firmware specifically states it fixes the problem you are having, firmware updates normally don't fix these types of problems. Trying to update the firmware when there are interface problems can damage the drive's firmware. An error when updating the firmware is usually caused by a problem with the drive interface or there is more than one drive connected to that IDE channel. IMPORTANT: do not interfere with the drive during the firmware update. If an error occurs during the upgrade process, or the upgrade process is cancelled during this process, damage to the drive can occur. If you experience any problems or have any questions, please contact our LG customer support line toll-free at 1-800-243-0000. hope this helps
Good day. I''m afraid you might have accidentally got the Operating System of your Samsung Tab corrupted. Im referring to your firmware. Usually if the firmware upgrade failed you need to retry it until it be successful. If you restart it or discontinue the process it will cause your Samsung Tab to be corrupted resulting into failure of the boot up process. You might need to contact samsung tech support for this or bring your equipment to the nearest center. They might need to check the software install and usually their software specialist will fix it for you. Sorry for what happen with your tab but i know the samsung repair center can fix it for you. Hope this information will be helpful to you. Have a great day.
Go ahead and do this, in case the DB is corrupted:
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
