Pump was running fine, I turned it off for a minute then went to turn back on and it would only hum. I had another Hayward pump that did the same thing and so I replaced it with another and now it is doing the same. I only had each for about two seasons before they died. I thought these were supposed to be very reliable pumps, can someone tell me what I could look for to find out why the just quit and started to hum. Thank you
SOURCE: Hayward Super Pump not turning on
it sounds like your pump is stack it could
bee that something is stack in the pump,
try somehow to turn the motor to see what is binding
get access thrue the pump.
G
SOURCE: Pump will not start and it just hums. When I
if it has been sitting since last year, some rust could have kept the shaft from turning. Get some pump pliers and try to rock the shaft. after you get it freed up, turn it back on.
David
SOURCE: Hayward 1 hp super Pump just hums then shuts off.
turn shaft manually wiyh pliers if somthing is stuck in propeller this should clear it
SOURCE: my hayward pool pump started making a humming
check impeller by turning shaft with pliers sounds as if its stuck do this while of and try to restart
SOURCE: Motor Hums,No Run
Inside the back case on the motor you'll see a white piece with two copper colored arms that have two silver points that almost touch. If these are rusty I've found that the motor won't turn over
. A quick fix is to take some 600+ grit Aluiminum oxide sandpaper and give each of those contact points a brisk sanding to remove any oxidation. This will help the points make a positive contact . Make sure while very obvious that the motor is unplugged first.
