I have a default code F10 on my frigidaire FEB27S5DBB electric single oven
SOURCE: Frigidaire Wall Oven
It is telling you that your oven has an issue. Check your owners manual for the fault code definitions. If you have a model number I may be able to find it for you.
SOURCE: Frigidaire FEB27T5D Electric Dbl Oven oven does not get hot
replace the upper oven calrod element it is an easy job just unplug the range turn the range around remove the back plate loosen the element wires from the element remove the element from the front any parts supply will have your replacment part such as www.applianceparts.com
SOURCE: F10 DIsplays on oven and beeps
Go to the Frigidaire web site if you don't have the manual and download it. I saw the F errors listed. They even have the electrical drawings.
SOURCE: F10 Error code on double oven.
Sir,
Check out this link
suggest to reset it by shutting off both main breakers to the stove , wait for one minute and switch breakers on again.
Thanks
Good Luck
Appreciate to rate as "Fixya"
SOURCE: kenmore model 790.9621 electric stove error code
it is the bake relay sticking--on the eletronic oven control board.i tried to buy the relays but,no luck.must buy the eoc board-great engineering
Good Morning mark, thank you for your post!
Based off the information you have provided your Frigidaire range is displaying an error code of "F10". An "F10" error code normally stands for a runaway temperature (overheating). This could be an issue with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would recommend performing a reset on your oven and you can do that by flipping the household circuit breaker off for ten minutes. If you continue to experience an issue with the "F10" error code I would recommend having a professional technician out to your home for proper diagnosis and replacement of any electrical components. This will help you avoid any unnecessary part purchases. Hopefully this information has been helpful. -Matt
Hello friend, thanks for the post!
I understand your Frigidaire wall oven is flashing a F10 code and not heating up. Based off of that information an F10 code stands for a runaway temperature, which could be an issue with a sensor probe or oven control. It could possibly be a miscommunication with the board and that could be cleared out by resetting your appliance. To reset your appliance disconnect power to it by unplugging the oven or flipping the household circuit breaker for ten minutes. If that step does not resolve your issue and you continue to receive the F10 code I would recommend contacting a technician to come and repair your appliance. I hope this information is helpful. -Matt
