Gilmour 030P 1.5 Quart Indoor Hand Pump Sprayer Logo
Irene Nessac Posted on Sep 04, 2012
Pump wont suction. Handle snaps back when pulled up
Is there some way to open the pump to see if it is clogged
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jan 20, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1406
Points
Top has a lock shaped like an X. It is difficult to turn but once the small protrusions at end of each arm of X snap out of locking holes the pump handle can be removed and the O-ring that produces the seal can be replaced into the grooved seat it fell off. To help keep it from happening again, just spray some water into the space around the handle shaft when the pumping action seems a bit strained due to the O-ring drying out.
Have lost suction on my shark rocket HV321 what do I check
1. A common place where loss of suction can happen is on the floor nozzle hose. At the base of the vacuum cleaner is a short hose about 6".
The hose will tear where it bends back and forth. You can find a replacement hose but to install it is difficult.
2. On the neck of the handle is a suction release window (valve). It is used to reduce suction power to vacuum curtains or clothes etc. The valve will often turn on accident and stay open reducing suction power. When the valve is opened, pushing and pulling the sweeper is easier.
3. The filters maybe dirty and clogged. Check ALL the filters. Some Sharks have 3 filters including HEPA. Shark HEPA filter are made of fiberglass therefore can be washed with the others.
4. Check for clogs anywhere dirt can travel until it reaches the dirt cup.
I have a Riccar Supralite Cordless that is clogged. I just replace the bag but whatever the vacuum picks up, it seems to be pushed back out. Is there a way to get to the vacuum tube to unclog it?
Start by checking the suction opening by the brushroll. Then remove the screws and take the nozzle cover off. Remove the cover to be able to inspect the impeller for clogs or debris. Pull the motor if necessary to gain access to the lower end of the suction tube/handle.
1helpful
I have almost no flow from my Hayward Sand Filter VL40T32. What do I need to do to get the flow back?
Look at your pressure gauge. If it is reading high, you have a clogged filter. Open filter and clean out or replace sand.
If it is reading low, you have a pump/ suction issue. Check the o-ring on the pump basket lid and make sure it is lubed and has no cracks. Check your basket for cracks. The pump impeller could be clogged. The pump may be pulling air in through a suction fitting or a small crack.
1helpful
What part do I need? It opens from the inside. The handle is not snapped.
Are you saying the inside door handle isnt snapped,but the door wont open by pulling on the inside door handle or is it the outside door handle thats not working??Both the inside and outside door handle has a spring and other components on the backside of the handle which cant really be seen unless you remove the whole door handle assembly.One of these components are most likely broken or the rod that attaches between each handle and the locking mechanism(part that locks into the door striker to keep the door closed and releases it too)might have come loose from the back of the handle.The outside handle is usually mounted to the door by pop rivets or bolts/nuts.The inside handle is usually mounted with screws,but it really depends on what kind of car youre driving.Youll probably have to remove the handle to inspect it for damage.Open the door and watch the locking mechanism for movement while youre pulling on the door handle.If it doesnt move when you pull on the handle,the handle is definitely broke or the rod has come loose from the back of the handle.
1helpful
Remove bottom of electrolux prolux upright vacuum. Hose is clogged.
You shouldn't have to remove disassemble the powerhead.
Lay vacuum on it's front. Between the tank and the powerhead is a black flex hose. Pull the end straight out from the powerhead. Then unscrew the tube from the tank using a clockwise turn. Remove the tube and visually check for clogs and splits. Clear or replace as needed.
If there's a clog in the powerhead behind the brush, this can be cleared using a wooden spoon handle or similar object.
If there's no clog in either place, there's a couple other possibilities. First, turn the vacuum back upright, open the hose flap, turn vacuum on, and place hand over opening to check for suction.
If there's a lack of suction, the bag needs replaced, the afterfilter beneath the bag needs cleaned, or the motor needs replaced.
If there is suction, put a coin in the opening inside the port and to the right as you're viewing the front of the vacuum. The coin should drop to the floor. A clog in thes section is unusual, but can happen.
If there is still no suction, take the vacuum to the nearest authorized Aerus Electrolux store for free diagnosis.
http://www.aerushome.com/storelocator/
There is a suction problem - the suction power is very low. The filter has been washed, dried and replaced but the problem is still there What is the problem? Thanks.
Something between the bag and the suction opening is clogging the vacuum. Start at the bag. Remove the bag and check for a clog. Remove the hose from the back and check for clog. Release the handle and turn the machine over to expose the sweeper bush. Check for clog. If you haven't found the clog at this point, remove the 4 screws on the brush cover. Then remove the brush and check the hose going into the machine. If the filters are clean the machine should have plenty of suction.
Bissell 35962 Cleanview Bagless Revolution Upright Vacuum hose is clogged with sock where hose meets handle attachment. Attempted to use broom handle to push back through suction opening. Sock is...
If you have access to a small sink "snake" used to clear clogs in sinks, you might be able to use it to "snag" the sock and pull it out. Needs to be a metal sewer snake so that you can tug on it if and when it snags the sock.
1helpful
Have a hoover model F5914-900 it wont spray anything out the hose attachment. The line isn't clogged any ideas?
Yes, one thing to try: With the hose attached, place your hand over the suction opening at the pick-up end of the hose. Then pull the trigger. The pump is suction driven, and if there is air in the water line in the hose, that is known to allow th hose to prime in about 10 to 15 seconds.
No suction when using the hose.
The beater bar is supposed to stop when the vac is upright. Sounds like you have a clog. There are several access points to check, fairly easy to clear obstructions.
4helpful
Clogged hose...
Hi!
Low suction, poor pickup, or no suction may be due to a clog in the vacuum cleaner. If you notice a change in the sound of the motor or a reduction in the spinning action in the Dirt Container, check for clogs. Unplug cleaner from electrical outlet. Empty Dirt Container. Check Upper Tank and Louvers for build up or clogs. Check to make sure Louvers are installed correctly. To unlock the Louvers, grasp the rim and turn toward the left. Pull straight down to remove. If the Louvers are missing or not locked into place, check and clear the tube in the center of the Dirt Container. Remove the Twist ‘n Snap Hose from the vacuum by turning to the left. Check the Suction Inlet, Hose and Hose Wand for clogs. Remove any clogs from the hose using a long, narrow object. Check the Foot Hose for clogs. If needed, remove the screw attaching the Hose Wand Base to the vacuum. Straighten the Foot Hose and unclog with a long, narrow object. If the clog persists, then check the Rotating Floor Brush the Air Passageway for obstructions.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Top Gilmour Garden Experts
Mike Cairns
Mike Cairns
ADMIN Andrew
ADMIN Andrew
Rick Rock
Rick Rock
Are you a Gilmour Garden Expert? Answer questions, earn points and help others
