Dryer was working fine, till we moved into a new apartment. Connected it up and turned it on, opened door to stop and smelled singe-like oder and dryer was very hot...tried to push on button again and won't start.
Either one or 2 things happened. The move cause the lint to shift around inside the dryer and it overheated blowing the fuse. OR the new apartment's vent is blocked and caused the dryer to overheat. All maytag dryers are not the same but they all have a non resetable fuse mounted on the blower housing. When the temp exceeds 350f it melts and kills power to the motor. If the motor is not running the heat does not get power. The motor must be turning to make the cent switch power up the heater. Dryer manuals
Dryer videos
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Anra, the problem is in the even heat board under the consol. This is a very easy job. Check out this link. Catriver, post back http://www.repairclinic.com/0080.asp
SOURCE: GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Thanks/Mike
SOURCE: I have a Kenmore Dryer
You have at least 3 problems, with your dryer; door switch, start switch and drum support. To to retire it for a replacement. Hope this helps!
SOURCE: How to replace door switch on old kenmore stac.dryer 110.88752792
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.Check online for the part repairclinic.com has it for $14.00 not bad
SOURCE: gas smell inside maytag neptune gas dryer
first of all, check to see if dryer vent is not plugged.
