SOURCE: cdx-mp40
You are correct, the unit powers entirely from the red and yellow leads. Your symptoms sound like a unit that isn't getting power on the red (switched) lead. The most likely cause is a blown fuse in your vehicle's fuse box.
SOURCE: Linking an i pod to a Sony CDX-MP40 using the bus input terminal
Some Sony head units let you use the Bus audio inputs as an auxiliary source input, but yours is not among them. To play your iPod through the head unit, you'll either need an iPod interface module: http://www.xplodsony.com/xplod/accessories/XA-110IP or an auxiliary input module: http://www.xplodsony.com/xplod/accessories/XA-300 The iPod interface will allow you to control and display the iPod directly through the head unit, while an auxiliary input adapter will allow the iPod to play through the head unit using the iPod's controls and display.
SOURCE: I HAVE LOST THE FRONT PANEL FOR MY SONY CDX MP40
i doubt you will be able to find one, if you do its going to be more expensive then the unit itself.
you have a look on ebay?? or your best of buying a new one!
hope this helps
alex
SOURCE: can the illumination colour be changed on the cdx
You will need an expert technician to open the unit, they are small bulbs with covered color lenses, usually small plastic caps. the simplies is to remove this caps and mark it with colored felt tips marker
SOURCE: CDX mp40 will skip when playing a cd everytime it gets bumped
122435678900566799878689866885689787896797689979088687768877698988768887878767886689985554587999877654323328900889
