Dirt Devil Featherlite Bagless Vacuum M085845Vacuum Logo
Posted on Sep 03, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I take the caps off of the brush on a dirt devil featherlite?
My brush is not spinning properly and is clogged with hair and lint. How do I take these caps off
Level 3:
  • Dirt Devil Master 18,429 Answers
  • Posted on Sep 04, 2012
Dirt Devil Master
Level 3:
Answers
18429
Questions
Helped
1404179
Points
62248
Here is the manual with instructions > http://dirtdevil.com/file/661/
5 Related Answers
Anonymous
  • Posted on Sep 19, 2008
SOURCE: DIRT DEVIL CLOGGING IN THE HOSE
What is the solution to this problem ?
Anonymous
  • 281 Answers
  • Posted on Apr 08, 2009
SOURCE: i cant get the power brush to work
can you turn the brush by hand? if it turns real freely the belt is broke or the brush siezed up make sure there isn't any carpet strans wrapped around the ends of the brush otherwise the brush won't turn.if its the belt make sure you clean the motor shaft before you put on the new belt,the old rubber from the old belt will make the new belt run unevevly and break again..good luck
Zachary Lewis
  • 3 Answers
  • Posted on Feb 01, 2010
SOURCE: dirt devil dynamite spinning thing isn't spinning
does the unit have a belt?
Billy Detlefsen
  • 159 Answers
  • Posted on May 10, 2010
SOURCE: The Dirt Devil Featherlite vacuum cleaner throws
You have a blocked vacuum hose take hose off and out side. Push the garden hose from one end to the other, this will push out the blockage
Ron Durham
  • 508 Answers
  • Posted on Oct 12, 2010
SOURCE: My dirt devil featherlite's brush
Does the motor spin?
How to fix dirt devil featherlite carpet cleaner loss of suction?
Hello! Below are general trouble shooting steps for your Dirt Devil vacuum to restore suction.
1. Check the hoses for clogs.
2. Clean and replace your filters if needed.
3. Check that your brushes are still spinning, if not, replace your belt with the recommended belt for your vacuum.
Hope this helps!
Spin brush
first thing to check is the belt drive could be that easy
How do you go about cleaning the rotating brush on the dirt devil bagless vacuum?
Using a sharp pocket knife or a utility knife making a single cut across the length of the roller is a good way to start. Then it is just a matter of pulling the strands or fabric and hair, etc., off. I like to inspect the end caps and bearings as well. A touch of grease of oil can help increase the life of your roller as well. ( for the bearings)
14helpful
Got Dirt Devil Featherlite,keeps burning the belt out immediately and there is only one way to put the belt on...have put on 4 new belts.....what up?
Hi There,
When a belt breaks immediately after installing it, this can ONLY mean one of two things. The first is that the belt was put back on incorrectly, and it may be pinched underneath of the beater bar. This would cause it to break immediately, but I seriously doubt after 4 belts that you put the belt on wrong all 4 times.
The second, and more probable cause is that your roller brush has gone bad. This could be why the belt broke in the first place. In order to test to make sure the brush is bad, unscrew the bottom plate, and remove the brush like you were changing the belt.
Hold the brush at the very end on both sides, using only your finger tips. While holding just the bearing caps, try spinning the bar with your thumbs. Does the brush spin freely in your hands? It should spin completely around 4-5 times on each spin. If the brush will not spin, or if you feel any resistance to it spinning, this is the reason why your belt continues to break.
If the brush can not spin, the motor shaft will continue to try and spin the belt, but since the brush doesn't spin, and the belt doesn't move, the motor shaft will just burn right through the back end of the belt.
If your machine is actually the model that's listed on this Fixya repair page, the Dirt Devil Featherlite model M085845, then your machine uses the following roller brush:
Dirt Devil Plastic Brush Roll for Model 085845 Part # 2-881020-000
The next time that change the belt, install the brush back into the machine, but this time pull up on the belt towards the brush to make sure that the belt spins freely, and spins the brush as well. If the belt doesn't spin the brush, there's some issue, and the belt will break as soon as you turn the machine on.
I hope this helped you. If you find out that you don't need a new brush, feel free to use the comment section here on the repair page and let me know, I'd be happy to walk you through some more advanced diagnosing. If you found this helpful, please be so kind and rate my repair and / or leave feedback for me.
Thanks so much,
Chris Jones
GoVacuum.com
No suction, belt is good and turing brush
take off the bottom cover, and see if something is clogged. trace it all the way to the impeller
Apr 14, 2009 • Vacuums
Top Dirt Devil Vacuums Experts
Mike Cairns
Mike Cairns
Paul Bade
NOEL
NOEL
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
