I need software fo hooking it up with the ethernet cables
Connect a LAN cable from Belkin to your laptop/computer's LAN port, open a browser on your laptop/computer and enter the Belkin's configuration URL. http://192.168.2.1
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
SOURCE: Wireless Repeater/Bridge (Belkin)
http://www.belkin.com/support/article/?lid=en&pid=F5D7230-4&aid=1564&scid=0reset to factory defaults and reset up your laptop All info at factorywebsite here at this web address.RICHARDM69
SOURCE: need drivers for the belkin
I recently purchased a Belkin router and had to update the firmware. I called Belkin who directed me to their UK site. The firmware is downloadable from the site BUT depends on the version of the router (this is written underneath). It will say eg ver.5000, corresponding to version 5; or, ver.4000 for version 4. You have to download that which corresponds to your version. Try this:
http://www.belkin.com/uk/support/article/?lid=enu&pid=F5D7632uk4A&aid=6105&scid=314
SOURCE: Belkin Wireless N router/Embarq 660 modem/No internet
THE PROBLEM IS THAT THE BELKIN RTR AND THE 660 HAVE THE SAME IP ADDRESS THE QUICKEST FIX IS TO RENAME THE LAN IP ADDRESS OF THE BELKIN RTR
SOURCE: Part # F5D8233-4 belkin wirless router need software cd
You don't need the cd. It has a connection wizard that helps set it up but you don't need to use that. You need to go to the belkin website and download the manual. That was also on the cd that's missing. Used to be a paper one in the box.
http://cache-www.belkin.com/support/dl/f5d8233-4_v1_manual.pdf
That will tell you how to get setup. For the most part routers run as is right out of the box. You will want to setup the wifi so you will need a SSID name to call it and then turn on the security. WEP or WPA are the usual suspects. Pick a 5 or 10 alphanumeric key. Turn on the wifi. Then you may need to enable dhcp so your computers will get ip numbers from the the router. Most of that is enabled by default on most routers. Wifi usually isn't as it requires more information.
SOURCE: Belkin F5D9230-4 Wireless G Plus MIMO Router setup
To set up the router , you don't need the CD.
you can do it manually.
First make sure that your computer is able to go online through the modem.
If yes then connect the modem and the computer to the router and set up your router.
Click here for step by step solutions
