LG 42LV4400 42 in. HDTV Logo
Anonymous Posted on Sep 03, 2012
TV will not turn on with remote or the power button on the tv
Back2life Electronics
Level 3:
  • LG Master 933 Answers
  • Posted on Sep 03, 2012
LG Master
Level 3:
Answers
933
Questions
6
Helped
274345
Points
2189
First verify that you have the set is plugged into a working outlet. If your outlet is fine, then you are either dealing with a power supply or main board failure. You will need to have the set properly diagnosed to be sure.
2 Related Answers
Anonymous
  • Posted on Mar 21, 2010
SOURCE: LG 26lx1d tv will not turn on. Power supply is
Have an LG26Lx1D for about 3 years, dropped off by my son.(Figures).Power light just blinking, but went back to red.Removed back panel, and metal cover. Just above antenna/cable input, its a small fan,mine was full of dirt. Blow off dirt, and make sure its turning freely.
Install back the covers, an voila....its a miracle...its working again.
Good luck
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Jul 16, 2010
SOURCE: tv on stand by, used power button on remote,
No green light in the front panel means the 5vdc standby may not be working at all, that will be the first place to look, without it nothing will run since the processor needs that 5vdc.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
How do I program this RCA nightclub universal remote for my Samsung smart TV
First understand that you need a little patience with this remote, it's a little slow, it may take a few seconds in between pushing buttons for it to react to your TV.
1)
-Turn on TV manually first.
we're going to try and get the remote paired to your particular tv
2)
-Facing RCA universal remote towards TV, press and hold both the POWER and TV buttons on the remote at the same time.. until the RCA universal remote POWER button lights up and is constantly on.
-Then press the PLAY button on RCA universal remote
(POWER button on remote should be blinking after pressing PLAY -- what the remote is doing is trying to program your TV with a list of codes. if your TV does not automatically shut off after a minute, press the PLAY button again. your TV should shut off. wait a few seconds before trying to press PLAY button again if you need to try again.)
3)
Assuming remote turned off TV. Now let's try to get the remote to turn on your TV
On the remote at top right is a REVERSE button, press that. You should see the POWER button on the remote blink once in response to you doing that.
Watch for the power on light on your TV.. your TV may take a few seconds to power on..
Wait a couple seconds. if your TV has not turned back on, press the REVERSE button again. the POWER button should blink once again in response
If your TV did not turn on. You may have to repeat pushing the REVERSE button waiting a couple seconds for the remote to try turning on your TV. For some people this can take several times, if not a dozen times. Just be sure to be patient and wait a couple seconds in between pressing the REVERSE button again. (what the RCA universal remote is doing is going through a list of codes trying to find the right model to pair to)
4)
Assuming the remote finally turned on your TV.. We are almost done. We programmed the remote to turn off the TV and turn on the TV. now we want to press the STOP button on the RCA universal remote to lock in those codes into the remote. After pressing the STOP button the light on the remote POWER button should turn off.
5)
We are done. You should be able to change the channels and raise and lower the volume of your TV.
Remote not active with the tv
unessr
I have provided instructions on how you can program your remote to your TV. Without knowing the brand TV you have, I have provided a link with the codes you can try.
Program to TV:
  • Remotes: Basic (Television Only)
    1. Turn the Television On.
    2. Press and hold the TV Power button for three seconds until the LED flashes.
    3. Enter the three-digit code using the buttons on the number pad.
    4. Press OK. Note: The LED will flash three times.
    5. Test functionality with the TV.
    6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Power Scan:
  • Remote: Basic Remote (Television Only)
    3. Press and release the TV Power button.
    4. Press and release the Up or Down Arrow on the remote until the television turns off.
    5. After the television turns off, press and release the OK button.
    6. Test functionality with the TV.
    7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
The link for the remote codes are at the bottom of the page. Select your receiver type and then your TV brand to get the codes.
http://www.dishnetwork.com/SupportSection/remote-setup
I hope this helps.
Ray Calo
DISH Network
1helpful
2answers
Need codes for programing a hitachi tv
The codes are, 0145,1145,...Step 1. Turn the TV on. 2. Press the TV button. 3. Press and hold the SET button until the LED blinks twice, then release. 4. Enter one of the four digit codes, the LED will blink twice. 5. Aim the remote at the TV and press the POWER button, if your remote does not have a power button, press PLAY, the TV should turn off, if not, try steps 1-5 again using a different code....hope this was helpful...
153helpful
3answers
Need instructions to add TV button to AKB36157102
1. While pressing and holding down the TV POWER button, press the CHANNEL UP or CHANNEL DOWN repeatedly until your TV is turned on (or turned off if you had it on). 2. Release TV POWER button when the TV turns on or off. The remote's TV POWER button will now control the TV.
Polaroid flm-2011 20 inch lcd television
 I will be happy to help.
  1. Turn tv on.
  2. Press and hold tv button on remote
  3. While holding tv button press and hold power(on/off) button, led light shold go off then back on after a coupke of seconds.
  4. Release both buttons.
  5. Aim remote at tv and press the power(on/off) button every 5 seconds until tv turns off.
  6. When tv turns off press the stop button at bottom of remote, that will lock in the code.
  7. Turn tv back on with remote and test all buttons.
Let me know if this helps and please rate this solution.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Need code
Hi beebeehuf, I will be happy to help.
  1. Turn tv on.
Lone99star
12helpful
3answers
Insignia TV code for RCA Universial Remote Control (RCR450)
If its a four digit code remote. I may be able to help.. Try these...0171, 1204, 1326, 1517, 1963, 2002..
Good luck
2helpful
3answers
Universal remote px-rc1
Hi! This worked for me! I'm Leyz/leheart from the Philippines. I'm typing in CDRKing or CD-R King or CDR King Universal Remote Control PX-RC1 so that these keywords will show up if someone's looking for it too.
Mcneileric is right!
Real TV should be on! On the remote, press and hold the SET and DEVICE TYPE (in my case TV) at the same time. (Note: SET button is not any other button but the one with the word SET on it. You might have been searching on youtube and found that they are pressing other SET buttons but do press the SET button with the SET word). Then press SET again. Press the POWER button then + CHANNEL button then POWER button then +CHANNEL button then POWER button then +CHANNEL. (This process is so the remote could look for the code while you are pressing the +CHANNEL and the POWER is to see if the tv will turn off/respond to the remote). Do this repeatedly until the time that when you press the POWER button, the real TV turns off which means the real TV now responds. You will be shocked so DON'T press the +CHANNEL button anymore as this will instruct the device to look for another code. Instead, press the DEVICE TYPE button (TV for my case) to finish the set up.
NOW YOU CAN USE the REMOTE! Press the POWER button and this will turn on the TV!
Again...
TV onPress and hold SET button (yes, the button with the word SET) and DEVICE type button (TV/VCR,etc) at the same time for about 3 secondsPress SET againPress Power to check if the TV turns off^^If nothing happens, press +CHANNEL to search for codePress Power again to check if TV turns off^^If nothing happens, repeat the step between ^^ and ^^If the TV now turns off after pressing the POWER button, press the DEVICE type button to finish the setup.
Mcneileric, THANK YOU!!!!
3helpful
My remote is not responding to the tv even i have changed the new baterry
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
28helpful
7answers
Silly remote
press and hold "set" then "TV" (or whatever device) then press "set" again. Point the remote at the device and press repeadly the power button until the device turns on. Press "TV" again to complete the programming procedure.
Done.!
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
