Laptop still comes on, screen also lights up but scren is cracked. cant make out anything. Dell flat screen monitor I've hooked up to my MPC Transport T2500 stays in safe mode. now I've hooked same monitor to my daughters Toshiba laptop and it will come on fine. so i know its not the Dell monitor.HELP,,, its driving me crazy
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
SOURCE: Toshiba satellite A100 Monitor problem
LCD issue it needs repair..call tosh if your laptop is still in warranty
SOURCE: how to reset the bios password on MPC transport x1000 laptop
the best way to remove a bios password is to have the bios reset by a program called "winternals" this can be done by any pc repair shop
SOURCE: Dell latitude d610 dark screen
there is a inverter in LCd that makes your lcd bright white shine. when it breaks down you see black screen. something happens on lcd you cant see clearly you should go to service and need to be changed INVERTER.
pls rate
SOURCE: Monitor not working on Dell Inspiron laptop. Inspiron 1501 laptop
just follow the given link ur problem will bw solved
http://www.experts-exchange.com/Hardware/Q_21896519.html
SOURCE: Black Screen Dell 600 Laptop
The display drivers maybe corrupt.
Boot the machine into safe mode. Right click on My Computer (XP) Computer (Vista) and select manage from the sub menu.
When the window pops up select Device Manager.
A device list will populate. When it has look down the list for Display Adapters. Click on the + icon next to Display Adapters to it expands. Right click on the display adapter and select uninstall.
Restart the computer and let it boot in normal mode.
If it boots in normal mode let it detect the Display and install the drivers for it.
I would be a good idea to update the display drivers via the Dell support website.
If it still won't display in normal mode please post back.
Good luck.
