You can download the manual from
http://www.retrevo.com/d/ds/progress?doc=d74782ab23218f4c972a807a9afa3fc7&rk=0.15356064987977386
To manually program your unit,
1. Manually turn on the device (
TV,
VCR, etc.) to be
controlled.
2. Press and hold the
SETUP button until the red
indicator stays on, then release the
SETUP button.
3. Press and quickly release the desired mode button
TV,
VCR, etc.). The red indicator blinks off once.
4. Press the
CHANNEL UP button repeatedly (up to
300 times) until the device to be controlled changes
channel. The red indicator blinks off with each
button press. If you accidentally overshoot the
code required, press the
CHANNEL DOWN button
to backtrack through the library until the device
changes channel. Pressing
CHANNEL UP changes
direction to forward again.
5. Press and release
MUTE to install the code.
Most users will store VCR codes under the
VCR button,
Cable codes under
CABLE, etc. If (for example) you
want to store a VCR code under
CABLE, first follow the
procedure for Direct Code Entry (previous page) and
press
CABLE in step 2 of Direct Code Entry, then enter
ANY VCR code in step 3 of Direct Code Entry. Then
follow the steps above for Code Search (or Brand
Search, below).
Note: If the device does not have a
CHANNEL UP button, use
PLAY (VCR only) or
POWER instead. Code Search starts from the currently
stored 4 digit number under that mode.
