Loops through assigning the IP address until it says to connect to a VPN. hit connect and wait in futility. have a Toshiba satellite laptop with an a10 and windows 7. have panda cloud anti. and i have installed the latest adobe.
You probably have a malware infestation.
Start
your PC and press F8 several times until the boot menu comes up. Then
select "Safe Mode with Networking". Now get some or ALL of the FREE
programs below.
Download, Install and Run Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
When Installing choose the non-pro version.
Download, Unzip, Install and Run TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Download, Install and Run Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
If you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Make sure to select ALL of the "threat categories" when you install or configure Avira.
You should be in pretty good shape if you run and install all of these programs.
SOURCE: What am I doing wrong? I
Expat Shield is for people trying to access UK programs from a non UK IP address. So not designed to work for you. You need something that gives you a US IP instead
SOURCE: Hi! I can`t get expat
that is most probably being caused by some addons. especially Adobe if you have it installed. try to uninstall it and then initiate expat shield 2.02. if it works, go for older Adobe programs.
Regards
SOURCE: When I try to connect to expat shield it will not
you have to edit your hosts file and add the ip of the servers of your
organization and also the names (an admin of the domain can help you)
you can find this file in
windows/system32/drivers/etc
then you should have no problem connecting to the dektop applications, etc...
For more details go to the following link:-
http://www.techyv.com/questions/error-accessing-vpn-remote-pc
SOURCE: internet keeps disconnecting once expat shield is up, why?
That's because Expat Shield is loaded with pop-under ads and other pieces of junkware and malware that kill your internet connection or bring it to a crippled crawl.
Testimonial: "Tks for these suggestions. I carried them out but I still the msg "navigation to this webpage has been cancelled" and the pop up blocker is active. Are there any other suggestions? Thanks in advance."
