Have "pay-as-you-go" Tracfone, but Tracfone's tech support tells me my old contact list is history... since I can't access the screen on my old phone, my phone numbers are "lost"... I would appreciate ANY ideas... maybe access the SIM card in my old phone...but, how do I do that? Take it to a computer store?
To transfer old phone contacts to new phone, you need to restore the lost contacts on your phone firstly, then you can move the data from old phone to new phone. Thus, you should know how to restore deleted or lost contacts on your old phone.
How to Recover Deleted Contacts from Android Phone
SOURCE: transfer contacts list
1. From the standby screen (the first screen when you open your phone), go to the menu.
2. Scroll to the address book and press select.
3. Scroll to the address you wish to copy (or any address if you want to copy all of them) and press the menu key.
4. Go down to copy and press select.
5. Select "Entries" to copy just that one entry or "All to SIM" if you
want to copy all your addresses to your SIM card, or "All to Phone" if
you want to copy them all to your phone.
6. Select Merge or
Override. Merge will combine any addresses that are already on your
card with the ones you are now copying, Override will replace anything
that is already there with the ones you are now copying. Be careful in
deciding which you want to do since Override will delete anything
previously saved and merge will duplicate any that were already saved
and are being saved again.
SOURCE: Copying contacts from Phone to Sim Card
1 take you to the main menu.
8 gets you to your contacts.
Very top left button with three dots gets you to options.
Then you have to hit the down button 12 times, to get to 'Copy to sim'.
Then hit 2, to select multiple.
Then hit the middle button to select all.
Then hit the very top left button again to copy.
And it will ask you to continue, and hit the very top left button one more time.
Then wait until it has copied them all.
But since you have no screen, you probably won't know when that is, unless it makes the noise it makes when it is done with something. Or just wait a few minutes until you think it is done copying.
Hope this helped.
SOURCE: transfer contacts from a sim card onto cell phone
Go to contact list and select the contact.press option button then press copy option then press copy to phone.
SOURCE: sony ericcson z310i blank screen
display ic is out so change the the display contact sony ericsion customercare
SOURCE: How do I transfer my contacts list to my sim card?
In standby mode, press Menu and select Contacts and press up or down button to select "Copy" to copy names and phone numbers all at once or individually from the internal phone book to the SIM phone book, or vice versa.
Hope this helps.
