Question about GE 46GW 948 46" Rear Projection Television
GE Rear Projection TV Color Alignment
We have a major problem with our TV! Some days it shoes more blue than the rest, some days more red then the rest. But everyday its blurry as all get up! We have tried the converence thing in the front settings of the TV. But that doesnt help no matter how we align the lines. We have opened the back to find a 6 screw panel on the right which works great at some time but eventually goes back to what it was, sometimes the very next time we turn the TV on again. We also recently found a 10 oxegon shaped screw panel which we just started to mess with even though there is no labels to it. All I can tell is one of them will adjust the vertical alignment of the screen. Now what is wrong with our TV & how can we fix this on our own! We arent in any shape to buy a new TV & we are willing to do it ourselves if we can! Before we lose our eyesight trying to watch TV!
Posted by wytchoftheni on
4 Related Answers
Vista Electronics
  • 1694 Answers
SOURCE: Blue Halo, Tried to adjust on Projection TV
The convergence issue you have will not adjust out....repair
of the convergence circuit will be necessary....then adjust...T.
Posted on Dec 03, 2007
Dewayne Turner
  • 87 Answers
SOURCE: Out of alignment
You have a problem on the convergence power supply board. The microprocessor in your set thinks it is a direct view set. This is usually caused by the regulator IC on the convergence power supply board. The type number is STK730-130 if I remember correctly.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Posted on Feb 09, 2008
Anonymous
  • 270 Answers
SOURCE: I have a ge 42 inch rear projection tv. The colors
It is possible, that the type of connection you have to your TV are crossed.
With COMPONENT cables, you have 3 plugs, red green and blue.
If this is the case, correct the plugs location to the correct plug.
Lens alignment results in a fuzzy (diffused) picture.
outside of that I too am at a loss.
good luck and don't forget to vote!!!
Posted on Sep 28, 2010
Ecollier2012
Edward
  • 3459 Answers
SOURCE: screen projector un aligned
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Oct 15, 2010
My hitachi rear projection tv has one of it's colors out of alignment almost like it's been bent because it causes the blue color to be out of alignment in a curved fashion across the screen the tv worked...
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 02, 2011 | Hitachi 50FX20B 50" Rear Projection...
I have a ge 42 inch rear projection tv. The colors are crossed and I was wondering if this is bnecause of the lenses out of alignment? if so, how can I adjust it? there is no setting for alignment.
Sep 28, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
Blue color is off and bowed at bottom
Needs the 2 convergence amplifiers replaced and then convergence alignment carried out(Could be pricy)
Dec 04, 2009 | Toshiba 50H81 50" Rear Projection...
Mitsubishi Rear Projection 65" tv picture becomes blurred bouncing right to left and color is red & green. TV is 8 years old approx. Any suggestions. Have not had any problems prevoiusly. First it woudl...
Sounds like possible solder connections on the convergence ICs. If so, you will see the red, green, and blue not lining up on ever input and even the mits menu. If you can bump it to correct, its just a solder connection, but if its out all the time then the ICs need replaced. This is a difficult repair only recommended for skilled technicians (40 solder connections + possible re-alignment needed)
Dec 03, 2008 | Mitsubishi WS-65809 65" Rear Projection...
All color guns out of alignment
Needs convergence amps replaced. Sometimes resistors burn and need to be replaced. This repair requires soldering/desoldering equip. and a trained eye, but usually can be done for 175.00-325.00 at a reputable service center. Good luck, Russmann.
Nov 01, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Alignment of color convergence
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Nov 17, 2007 | Pioneer SD-643HD5 64" Rear Projection...
Blue Convergence Problem
This is a pain and you have to be carful in doing this fix. Its basically the bulb thats shot, its got that liquid in it so DO NOT BUST IT OR YOU WILL SCREW THE BOARD UP! THen you have to get a new TV
Oct 26, 2007 | Philips 46PP9302 46" Rear Projection...
Color guns out of alignment
It sounds to me like the convergence amps themselves have failed. Ic7001 and Ic7002, both are STK392-110 Sanyo built Ic's and not an expensive job for a qualified shop. When shopping around for a shop to repair it ask what they charge for replacement of the convergence amps in this unit. And take the unit to them to save pickup and delivery charges...
Have a great day!
Bill
Dec 21, 2006 | Panasonic PT-53WX53 53" Rear Projection...
Color problem with Toshiba
Sounds like a problem with convergence, poss just requires new STK 392-110 ICs , may need a couple of resistors that go due to faulty ICs
Nov 02, 2006 | Toshiba 50A61 50" Rear Projection...
Open Questions:
See all GE 46GW 948 46" Rear Projection Television Questions
GE 46GW 948 46" Rear Projection Television Logo
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
