Toshiba 15LV505 LCD TV Logo
Dave Johnson Posted on Sep 02, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tv displays color screens only - Toshiba 15LV505 LCD TV
Level 3:
Top Expert:
  • Toshiba Master 76,851 Answers
  • Posted on Sep 03, 2012
Toshiba Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14986539
Points
237762
Want more details to post a solution to this problem. Provide more details please.
Samsung LED TV, Model# UN55B6000VFXZA turns on to black screen then displays large blocks of colored vertical lines?
check every flat cable main boerd to t-con t-con to display if dont help display is a problem
2helpful
2answers
Black screen for HDTV channels -- but TV menu and DVDs display normally
Try hard reset, Please unplug the tv cables and power cables for 30 min and redo the cable and check its working ....
Good luck...
Screen has reversed colors (appears to look like a color negative). Everything seems to work ok. Repairable?
hello , just you need to enter to the picture options and change the display screen or display color , or change the mode it would be an NTSC mode you should change it
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
1helpful
Screen is displaying Red background color with glittery pixels effect around the figures
Please change the T-CON board, if it did not fix the problem, you may have a defective LCD Panel.
Sony dvp-ns425 player has the word VIDEO in upper right corner appear and disappear every 20 seconds or so. It is in the same green block letters as all the menu/control titles so I know it is from the dvd...
That word Video in green color could be TV's on-screen display as DVP-NS425 has another kind of on-screen display that has track info, time info etc in display.
Please press Display on TV remote to turn off that green color Video on-screen display at top right corner.
Thanks.
2answers
Emerson tv model no. ewf2704
Hi: When you say small horizontal screen, ¿Do you mean picture does not fill the screen completely from top to button? ¿Do images display normally though they are smaller in size? ¿Is color and definition of signal OK? Please answer so I can have a better picture of the problem.
Same as other poster: Player only plays black and white
It sounds like the circuitry which actuates the color drives for the screen are not working, this would ba analogous to adjusting for a B&W picture on a color TV you have color but the screen shows black and white. I would get a schematic for this set and measure the voltages on the color processor that connects to the screen since you know that the external jack has color. If possible I can help you troubleshoot this, if you need me to help out.
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
